[GeoNode-users] Error in the maximum zoom in preview and maps
Alessio Fabiani alessio.fabiani at geo-solutions.it
Sat Jul 7 07:31:55 PDT 2018
Fixed by
https://github.com/GeoNode/geonode/commit/5761b91e3f460c5f7cf4f89a3f00df24c8db3cf2
Il giorno gio 24 mag 2018 alle ore 16:13 Andres Juarez <
albertoandres.juarez at gmail.com> ha scritto:
> Alessio, I changed the subject
> This happens with all types of layers, both in the preview and in the maps.
> When zooming to the extension of the layer (epsg: 22195) the coordinates
> requested to gesoserver are these:
> Bbox = SRSEnvelope [-6535977.413699: -6535900.9766708, -4094502.2935821:
> -4094425.8565538]
> Then I take the maximum zoom (1: 1066) and the coordinates requested to
> geoserver are these:
> Bbox = SRSEnvelope [-3912505.7292604: -3912429.2922321, -8783837.5411966:
> -8783761.1041683]
> or these others with a WMS (epsg: 22185) loaded through the local
> geoserver:
> Bbox = SRSEnvelope [-1.001875417E7: -5009377.085, -5009377.085: 0.0]
> And I find these errors in the geoserver log:
> [geoserver.gwc] - Error dispatching tile request to GeoServer
> org.geowebcache.grid.OutsideCoverageException: Coverage [minx, miny, maxx,
> maxy] is [176532, 208496, 176735, 208663, 19], index [x, y, z] is [210959,
> 147229, 19]
> Thank you very much for the help!!
> 2018-05-24 5:09 GMT-03:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Hi all,
>> @Elton, about GeoNode 2.8.1 please read below [1]
>> @Andres, if you could put together a use case description along with some
>> sample data, it would be very helpful to debug the issue and figure out a
>> solution.
>> [1]
>> *2.8.0 -> 2.8.1*
>> Mostly bugfixes. The only new relevenat features are:
>>  - Download Original Dataset link
>>  - Monitoring contrib module make use of GeoIP2
>>  - RemoteServices support for ArcGIS Map layers and GeoNode harvesing
>>  - api/layers API change -> added more metadata fields
>>  - Support for native projections
>>  - Support GeoServer 2.13.x
>> Migrations:
>>  - ResourceBase: added "uploadsession" foreign key
>>  - Layers: altered file filed in order to upload to date-time subfolder
>> You can see the detailed list of changes from here
>> https://github.com/GeoNode/geonode/pull/3809/files
>> *2.8.1 -> 2.10.0*
>> Differences are only on Django version and test runner
>> *apt-get*
>> Unless I am able to find some time to work on debian package (or there's
>> some volunteer work), apt-get install won't be able to update the code by
>> itself.
>> Nevertheless it can still be done manually. Probably I can send
>> instructions to do that.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-05-24 6:33 GMT+02:00 Andres Juarez <albertoandres.juarez at gmail.com>:
>>> Hello Elton
>>> I tried this that Alessio suggested to me, and solved the problem of
>>> zooming to the extension of the layer.
>>> on the maps you can apply this fix here (should be easy)
>>> https://github.com/GeoNode/geonode/pull/3732/files
>>> If you would like to allow GeoNode storing (and managing) the original
>>> bbox / srid, you should consider this one also
>>> https://github.com/GeoNode/geonode/pull/3698/files
>>> In particular this solved the zoom problem:
>>> https://github.com/GeoNode/geonode/pull/3698/files#diff-c0e1c8cea0b01d04a691f88381580c4f
>>> However now I am testing with this installation method
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>> where the zoom to the extension works, but I have another problem when I
>>> reach the maximum zoom level (1: 1066) and then I pan, the map goes to
>>> strange coordinates.
>>> My layers are in coordinates in meters (epsg: 22185) and I use the base
>>> map of OSM by default, and I can not reproject the layers because they come
>>> from another Postgis database.
>>> Maybe Alessio can help us ...
>>> Good luck! and thanks in advance
>>> 2018-05-23 14:45 GMT-03:00 Elton Davis Turin Espinoza <eturine at uni.pe>:
>>>> Hi Andres,
>>>> Could you patch your code so that the zoom works?
>>>> I have the same problem, please help me.
>>>> Hi Alessio,
>>>> I found a commit
>>>> <https://github.com/GeoNode/geonode/commit/b4b08f345c9655b3d044e7d08938cb59c0b99c8d>that
>>>> edits the utils.py and it does not work for me, do you know which other
>>>> file is modified?
>>>> Can you please tell me about when the Geonode 2.8.1 will be relesead?
>>>> I'm looking forward to it soon...
>>>> Thank you so much
>>>> Elton
>>>> 2018-04-11 12:29 GMT-05:00 Andres Juarez <
>>>>> Thanks Alessio
>>>>> This solved the problem in "uploadlayers".
>>>>> The zoom to the layer extension still shows incorrectly.
>>>>> Can it be solved in a simple way?
>>>>> Thank you again!
>>>>> 2018-04-11 13:10 GMT-03:00 Alessio Fabiani <
>>>>>> Yep,
>>>>>> this issue has been fixed on master branch (future 2.8.1 version).
>>>>>> For a quick fix just do
>>>>>> vim  /usr/local/lib/python2.7/dist-packages/geonode/
>>>>>> geoserver/helpers.py
>>>>>> -- go to line  614
>>>>>> replace
>>>>>>     "srid": resource.srid
>>>>>> with
>>>>>>     "srid": resource.projection
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> 2018-04-11 18:02 GMT+02:00 Andres Juarez <
>>>>>>> Hello everyone
>>>>>>> I just installed stable version 2.8 using APT in Ubuntu 16.04 also
>>>>>>> newly installed. Geonode works and I can load layers, edit metadata, etc.
>>>>>>> I have found two problems, perhaps related:
>>>>>>> 1- When viewing the layer information, the preview takes me to an
>>>>>>> erroneous extension, however if I look for the location manually the layer
>>>>>>> looks correct. The same happens when creating a map with any layer.
>>>>>>> 2- I have connected in geoserver another postgis database and
>>>>>>> published several layers. When executing "updatelayers" it shows me the
>>>>>>> following error:
>>>>>>> Traceback (most recent call last):
>>>>>>>   File "/usr/bin/django-admin", line 9, in <module>
>>>>>>>     load_entry_point('Django==1.8.19', 'console_scripts',
>>>>>>> 'django-admin')()
>>>>>>>   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>>> 354, in execute_from_command_line
>>>>>>>     utility.execute()
>>>>>>>   File
>>>>>>> 346, in execute
>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>>>>>>> 394, in run_from_argv
>>>>>>>     self.execute(*args, **cmd_options)
>>>>>>>   File
>>>>>>> 445, in execute
>>>>>>>     output = self.handle(*args, **options)
>>>>>>>   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>> line 122, in handle
>>>>>>>     execute_signals=True)
>>>>>>>   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>>> 614, in gs_slurp
>>>>>>> Exception: ('Failed to process ancho_calle',
>>>>>>> AttributeError("'FeatureType' object has no attribute 'srid'",))
>>>>>>> The same happens with the layers loaded by the Geonode interface, it
>>>>>>> shows the same error.
>>>>>>> What can I do to solve it?
>>>>>>> Greetings and thanks in advance.
>>>>>>>    Andrés Juarez
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>    Andrés Juarez
>>>> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
>>>> entidad que se muestra como destinatario/s y pueden contener datos
>>>> personales y/o información confidencial, sometida a secreto profesional o
>>>> cuya divulgación esté prohibida en la legislación vigente. Que
>>>> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación,
>>>> reproducción u otra acción al respecto por parte de personas o entidades
>>>>  distintas al destinatario/s. Si ha recibido este mensaje por error, por
>>>> favor, contáctenos a la siguiente dirección de correo electrónico
>>>> lpdp at uni.edu.pe y proceda a su eliminación.
>>>> En cumplimiento a lo establecido en la Ley de Protección de Datos
>>>> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
>>>> son almacenados bajo la confidencialidad y las medidas de seguridad
>>>> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
>>>> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
>>>> usted podrá ejercitar los derechos de actualización,
>>>> inclusión, rectificación, supresión u oposición, enviando un mensaje al
>>>> correo electrónico anteriormente señalado e indicando en el "Asunto" el
>>>> derecho que desea ejercer"
>>>    Andrés Juarez
>    Andrés Juarez
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180707/cc8672c4/attachment-0001.html>
More information about the geonode-users mailing list
