[GeoNode-users] Updatelayers large dataset
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jul 9 01:19:48 PDT 2018
Hi Mark,
it is worth trying to rise up the OGC server TIMEOUT on settings
See as an instance here
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L769
Unless the issue comes from the database or something else.
Il giorno lun 9 lug 2018 alle ore 06:32 Mark Davis <MarkDa at hume.vic.gov.au>
ha scritto:
> Hi,
> I am receiving the error below on larger layers when running updatelayers.
> Any Genode/Geoserver settings that would help? Current layer I am
> attempting is ~100,000 polygons.
> >python manage.py updatelayers -f LAYER_NAME
> error(10053, 'An established connection was aborted by the software in
> your host machine')
> Thanks,
> Mark
> Confidentiality
> This information is Confidential. The information contained within this
> transmission is directed to the defined recipient(s). Should this
> transmission accidentally find its way to an incorrect recipient then it
> should be destroyed immediately without disclosing or using the information
> contained within the transmission. If you have received this transmission
> in error then please inform the sender immediately by return email and
> delete the transmission and all of its associations. Any views expressed in
> this email are those of the individual sender and may not necessarily
> reflect the views of Hume City Council.
> The Hume City Council has implemented anti-virus software, and whilst all
> care is taken, it is the recipient's responsibility to ensure that any
> attachments are scanned for viruses prior to use. The Hume City Council
> monitors its email traffic.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180709/4b74ec2e/attachment-0001.html>
More information about the geonode-users mailing list
