[GeoNode-users] Geoserver keeps CPU at 100%
Simone Giannecchini simone.giannecchini at geo-solutions.it
Wed Jul 11 07:07:11 PDT 2018
Dear Stefano,
something like that happens usually when you have large raster dataset that
are not optimized and you put them under load.
Does this ring a bell?
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Wed, Jul 11, 2018 at 9:10 AM <Stefano.LUONI at ext.ec.europa.eu> wrote:
> Hi everyone,
> I've been experiencing a strange issue for a few days now and I didn't
> manage to solve it yet. There is something wrong with Geoserver's Java
> threads, as after some usage, the navigation on website suddenly becomes
> slow and when executing a "top" on server, I find all CPU cores at 100% and
> a long list of tomcat8 processes running, even if no one is accessing the
> site.
> Unfortunately, checking the logs doesn't give me a clue of what's
> happening, as warnings and errors are constantly changing and so far I was
> not able to spot the exact moment when Java failures are triggered.
> I'm running Geonode 2.7.5, with Geoserver 2.12 snapshot on an Ubuntu 16.04
> Server. I already tried upgrading both tomcat8 and OpenJDK from apt, but it
> didn't solve the issue.
> These are building infos on Geoserver:
> *Build Information*
> *GeoServer Version*
> *2.12-SNAPSHOT*
> *Git Revision*
> *ba5175e3bcc4a5d2bc472809eccad682cc180cd8*
> *Build Date*
> *29-Mar-2018 14:27*
> *GeoTools Version*
> *18-SNAPSHOT (rev c41e79c4aaa3ec2db3b0f1e1ed4a5d485fddb75a)*
> *GeoWebCache Version*
> *1.12-SNAPSHOT (rev
> fd34a157375068f0a88f43f4abef154daaca7017/fd34a157375068f0a88f43f4abef154daaca7017)*
> I also tried updating Geoserver version to 2.13, but some layers (defined
> by SQL queries) stopped working, hence I had to rollback to 2.12.
> This machine has been running fine for months, and only a few days ago
> started having this issue; we didn't install anything new, so I'm wondering
> if any of the layers uploaded is somehow causing the problem.
> I attached an extraction of Geoserver log, hoping this can give you some
> hints.
> Thanks,
> Stefano
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180711/606e29f3/attachment-0001.html>
More information about the geonode-users mailing list
