[GeoNode-users] Layer Group in Geonode,
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jul 12 01:19:26 PDT 2018
Hi Leonardo,
currently this it not directly supported on GeoNode. Nevertheless, with the
latest GeoNode versions, you can easily "simulate" this by adding your
GeoServer instance as a RemoteService of your GeoNode instance. You can
then publish layers available in GeoServer as well. They will remain
read-only layers, of course.
Il giorno mer 11 lug 2018 alle ore 22:50 Leonardo Jauregui <
leojauregui.geog at gmail.com> ha scritto:
> I Ask like BRuce Crevensten did.
> Is it possible to configure a layer in GeoNode that uses a "Layer Group"
> that is created within GeoServer?  I'm trying to do something like this:
> 1. Upload various layers in GeoNode,
> 2. Compose a Layer Group in GeoServer from these layers, using the
> GeoServer web interface,
> 3. Create a new layer, or do something to make a new layer in GeoNode
> display that Layer Group.
> Step 3 is where I'm unclear what to do.  I tried a few variations of using
> the Django admin interface to directly edit a Layer (and a MapLayer) to
> attempt to point at the layer group, but wasn't successful.
> Also, I saw that the documentation does discuss creating a layer group:
> http://docs.geonode.org/en/master/tutorials/advanced/adv_data_mgmt/pretty_maps/base_map.html
> ....but that tutorial continues to discuss uDig, not GeoNode.
> Is this functionality supported?  If not, would this be something of
> interest to others?
> Thanks!
> Leonardo Jauregui
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180712/70fe1636/attachment-0001.html>
More information about the geonode-users mailing list
