[GeoNode-users] Managed hosting options for GeoNode as a service
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jun 13 01:22:03 PDT 2018
Uhm, unfortunately on GeoNode we are far from having the possibility to
apply updates from the GUI yet.
A solution similar to this one, which still requires a minimum effort
though, is to install GeoNode through Docker and Rancher.
https://www.geo-solutions.it/blog/one-click-geonode-with-rancher-and-docker/
We are finalizing in these days the possibility of automatically update the
customized instance of GeoNode image through the Rancher interface, by
keeping all the customizations, accounts and datasets already available on
the geospatial portal.
Il giorno lun 28 mag 2018 alle ore 23:42 Jac Steiner <jackrsteiner at gmail.com>
ha scritto:
> Hi Alessio,
> Thanks so much for this response, I truly appreciate your help.
> In terms of viable hosting options, generally I completely agree with you,
> AWS is a good solution. But, in this case, I'm looking for a host that
> offers GeoNode as a service -- all systems administration is managed by the
> vendor (hosting, software updates, security of server, installation for all
> GeoNode components) but the content is managed by the client. Perhaps this
> isn't viable because GeoNode installs have a fair amount of configuration
> that can NOT be done from within a web interface. Theming is the major
> example that jumps to mind. Notably, installing a database and geoserver,
> and configuring them to work with a GeoNode instance is NOT what I'm
> talking about, as those are precisely the tasks I'm looking to be managed
> by vendor for the client.
> Maybe I should enumerate a use case
>  A client wants to set up a geoportal and chooses the GeoNode platform.
> They have no IT infrastructure on premises. They have an employee that
> presently manages their Wordpress website, which is hosted by
> wordpress.com. This employee manages user accounts and permissions for
> access to the website via browser. All critical updates to the server are
> managed by wordpress.com. All updates to their instance of wordpress can
> be triggered using the web interface. The employee can also update the site
> to reflect branding changes using the web interface. When their use of
> server resources exceeds their monthly plan, they are contacted by
> wordpress.com and offered to upgrade their service to meet demand. The
> client is looking for a similar experience for their GeoNode instance.
> Maybe this use case is better suited to ArcGIS Online, or something else.
> I'm all ears.
> Appreciate everyone's help,
> Jac
> On Mon, May 28, 2018 at 7:06 PM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Jac,
>> did you considered also Amazon Web Services option? We installed custom
>> dockerized versions of GeoNode for several customers already.
>> Cannot be much helpful on the other options as I'm not really involved on
>> DevOps stuff, and I have no personal experience with the ones you listed.
>> 2018-05-26 1:15 GMT+02:00 Jac Steiner <jackrsteiner at gmail.com>:
>>> Hi GeoNode users,
>>> I'm presently reviewing available options for GeoNode as a service,
>>> fully managed solutions. The key features are that install, updates, and
>>> security of the GeoNode platform are managed, but the client obviously is
>>> the administrator for the CMS.
>>> Thus far, I've found less than a handful of options:
>>>    - MapServerPro
>>>    <https://www.mapserverpro.com/cr-articles/geonode_hosting.php> -
>>>    Looks to be a standard shared and VPS server provider specializing in GIS
>>>    application. For $100 a month you get a VPS with GeoNode. It's unclear
>>>    whether that includes ongoing support for GeoNode stack updates.
>>>    - acuGIS <https://www.acugis.com/geonode-hosting.html> - Also looks
>>>    to be mainly a host provider. More explicit in it's feature set for GeoNode
>>>    hosting and only $50 a month. Still unclear if ongoing support is provided
>>>    for updates.
>>>    - Boundless Exchange <https://boundlessgeo.com/boundless-exchange/>-
>>>    They appear offer a fully managed
>>>    <https://boundlessgeo.com/managed-services/> GeoNode as a service,
>>>    with one caveat -- Boundless calls it Exchange which I think is basically a
>>>    rebranding of GeoNode with GeoGig enabled by default. Pricing is only
>>>    available through quote request. I'm also a little concerned if Boundless's
>>>    offerings may diverge from stock GeoNode, as they look to be jockeying to
>>>    be the RedHat of GIS (not a criticism).
>>> If anyone has more information on these three providers or others, I'd
>>> greatly appreciate it. Happy to answer any questions as well.
>>> Best wishes,
>>> Jac
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A -
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>  Massarosa
>> (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180613/bb01e775/attachment-0001.html>
More information about the geonode-users mailing list
