[GeoNode-users] Installed Geonode
Mark Davis MarkDa at hume.vic.gov.au
Thu Jun 14 01:01:13 PDT 2018
Managed to get this installed when using default geonode install path on C:/
Looks like when not using this it was causing issues.
Any idea which config files need to be changed to go from Localhost to server name? Thanks
From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On Behalf Of Mark Davis
Sent: Tuesday, 12 June 2018 6:07 PM
To: geonode-users at lists.osgeo.org
Subject: [GeoNode-users] Installed Geonode
Have installed GeoNode-2.6.x to Windows 2016 standard 64bit.
I do not seem to be able to load http://localhost/. The page tries to load with no response.
I can access http://localhost:8080/geoserver with no issues, and can log in.
Windows binary install guide does not mention any more details.
All 3 services seems to be runnings.
Postgresql
Apache tomcat
Apache2
Have tried adding the environment variables to see if that was the issue from looking at the manual install guide, but no change.
Any suggestions?
Thanks,
Md6
Confidentiality
This information is Confidential. The information contained within this transmission is directed to the defined recipient(s). Should this transmission accidentally find its way to an incorrect recipient then it should be destroyed immediately without disclosing or using the information contained within the transmission. If you have received this transmission in error then please inform the sender immediately by return email and delete the transmission and all of its associations. Any views expressed in this email are those of the individual sender and may not necessarily reflect the views of Hume City Council.
The Hume City Council has implemented anti-virus software, and whilst all care is taken, it is the recipient's responsibility to ensure that any attachments are scanned for viruses prior to use. The Hume City Council monitors its email traffic.
Confidentiality
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180614/e0799b45/attachment.html>
More information about the geonode-users mailing list
