[GeoNode-users] Problem with GeoFence permissions
Paolo Corti pcorti at gmail.com
Mon Mar 5 17:08:02 PST 2018
Hi Daniel
can you try to remove the line with the print statement and see what
kind of error is raising?
Paolo
On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi Paolo,
> Thanks for the tip. However, I installed GeoNode from the APT repository and
> I have no idea how to upgrade GeoNode or change GeoFence store from H2 to
> PostgreSQL.
> I also added time.sleep(5) in sync_geofence.py, right before the try block
> but I'm still getting an error: It fails with the message:
> ('Unexpected error:', <type 'exceptions.AttributeError'>)
> Traceback (most recent call last):
>   File "/usr/bin/django-admin", line 21, in <module>
>     management.execute_from_command_line()
>   File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 354, in execute_from_command_line
>     utility.execute()
>   File
> 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
> line 60, in handle
>     print 'perm_spec is %s' % perm_spec
> UnboundLocalError: local variable 'perm_spec' referenced before assignment
> Any other tips on how to fix this permission mess-up?
> Thanks
> Daniel
> On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com> wrote:
>> Another option could be to run a time.sleep for some seconds after
>> each layer iteration in sync_geofence command
>> cheers
>> Paolo
>> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> > Hi Daniel
>> > You seem to have hit this bug which I reported to GeoFence team in the
>> > past:
>> > https://github.com/geoserver/geofence/issues/98
>> > I didn't notice this happening in latest GeoFence version, so
>> > upgrading to latest GeoNode could be an option.
>> > Or you could try to use PostgreSQL instead than H2 as a GeoFence store
>> > hope this helps
>> > cheers
>> > Paolo
>> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
>> >> Update: Apparently, if I update the layer permissions in the web
>> >> interface
>> >> or if i run `geonode updatelayers -f <layer_name>`, the correct
>> >> GeoFence
>> >> permissions are created. Thus, doing so a layer at a time works. But
>> >> several
>> >> layers at once, no.
>> >> What should I look for in the GeoServer log to try to figure out where
>> >> the
>> >> problem is occurring? I can attach the GeoServer log if that helps.
>> >> Cheers
>> >> Daniel
>> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
>> >> wrote:
>> >>> Hi list,
>> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine. Right
>> >>> now i
>> >>> have 108 registered layers, some imported using the web interface,
>> >>> some
>> >>> using the `geonode importlayers` command.
>> >>> Last week I noticed that some of the layers I was importing using the
>> >>> management command had view permission problems. I realized that the
>> >>> cause
>> >>> was that the GeoFence rules were not being created correctly.
>> >>> Looking at the messages on the list, I saw that there were some
>> >>> discussions about this issue and that 1) there was a patch for
>> >>> geoserver/helper.py [1] and 2) a new `sync_geofence` management
>> >>> command.
>> >>> I applied the patch and downloaded the `sync_geofence` command.
>> >>> Now, every time I run `geonode updatelayers` I end up with a different
>> >>> set
>> >>> of rules in GeoFence. Some times with 106 rules, some times with 209
>> >>> rules
>> >>> etc. And I can't run `geonode sync_geofence` since I'm getting an
>> >>> error:
>> >>> assignment
>> >>> Any idea how to fix this issue so I don't have to manually create the
>> >>> GeoFence rules? And also, not have `geonode updatelayers` mess up the
>> >>> rules
>> >>> already created?
>> >>> Cheers
>> >>> Daniel
>> >>> [1] -
>> >>> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> > Paolo Corti
>> > Geospatial software developer
>> > web: http://www.paolocorti.net
>> > twitter: @capooti
>> > skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
