[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria daniel.victoria at gmail.com
Tue Mar 6 04:11:35 PST 2018
Hi Paolo,
There are 2 print statements in the except block. The first prints the
error and the second is the one that complains about the variable
'perm_spec' referenced before assignment.
If I comment out just the second print statement I the following message
printed to the screen, one for each layer registered in GeoServer
('Unexpected error:', <type 'exceptions.AttributeError'>)
I tried to run the commands in a python interpreter to debug this. But I
could not get the environment set. When I import the geonode.layers.models
in the interpreter, it complains about django_settings_module.
Cheers
Daniel
On Mon, Mar 5, 2018 at 10:08 PM Paolo Corti <pcorti at gmail.com> wrote:
> Hi Daniel
> can you try to remove the line with the print statement and see what
> kind of error is raising?
> Paolo
> On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
> > Hi Paolo,
> > Thanks for the tip. However, I installed GeoNode from the APT repository
> and
> > I have no idea how to upgrade GeoNode or change GeoFence store from H2 to
> > PostgreSQL.
> > I also added time.sleep(5) in sync_geofence.py, right before the try
> block
> > but I'm still getting an error: It fails with the message:
> > Traceback (most recent call last):
> >   File "/usr/bin/django-admin", line 21, in <module>
> >     management.execute_from_command_line()
> >   File
> > "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line
> > 354, in execute_from_command_line
> >     utility.execute()
> >   File
> line
> > 346, in execute
> >     self.fetch_command(subcommand).run_from_argv(self.argv)
> >   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> > line 394, in run_from_argv
> >     self.execute(*args, **cmd_options)
> > line 445, in execute
> >     output = self.handle(*args, **options)
> >   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
> > line 60, in handle
> >     print 'perm_spec is %s' % perm_spec
> > UnboundLocalError: local variable 'perm_spec' referenced before
> assignment
> > Any other tips on how to fix this permission mess-up?
> > Thanks
> > Daniel
> > On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com> wrote:
> >> Another option could be to run a time.sleep for some seconds after
> >> each layer iteration in sync_geofence command
> >> cheers
> >> Paolo
> >> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
> >> > Hi Daniel
> >> > You seem to have hit this bug which I reported to GeoFence team in the
> >> > past:
> >> > https://github.com/geoserver/geofence/issues/98
> >> > I didn't notice this happening in latest GeoFence version, so
> >> > upgrading to latest GeoNode could be an option.
> >> > Or you could try to use PostgreSQL instead than H2 as a GeoFence store
> >> > hope this helps
> >> > cheers
> >> > Paolo
> >> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
> >> >> Update: Apparently, if I update the layer permissions in the web
> >> >> interface
> >> >> or if i run `geonode updatelayers -f <layer_name>`, the correct
> >> >> GeoFence
> >> >> permissions are created. Thus, doing so a layer at a time works. But
> >> >> several
> >> >> layers at once, no.
> >> >> What should I look for in the GeoServer log to try to figure out
> where
> >> >> the
> >> >> problem is occurring? I can attach the GeoServer log if that helps.
> >> >> Cheers
> >> >> Daniel
> >> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
> >> >> wrote:
> >> >>> Hi list,
> >> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine. Right
> >> >>> now i
> >> >>> have 108 registered layers, some imported using the web interface,
> >> >>> some
> >> >>> using the `geonode importlayers` command.
> >> >>> Last week I noticed that some of the layers I was importing using
> the
> >> >>> management command had view permission problems. I realized that the
> >> >>> cause
> >> >>> was that the GeoFence rules were not being created correctly.
> >> >>> Looking at the messages on the list, I saw that there were some
> >> >>> discussions about this issue and that 1) there was a patch for
> >> >>> geoserver/helper.py [1] and 2) a new `sync_geofence` management
> >> >>> command.
> >> >>> I applied the patch and downloaded the `sync_geofence` command.
> >> >>> Now, every time I run `geonode updatelayers` I end up with a
> different
> >> >>> set
> >> >>> of rules in GeoFence. Some times with 106 rules, some times with 209
> >> >>> rules
> >> >>> etc. And I can't run `geonode sync_geofence` since I'm getting an
> >> >>> error:
> >> >>> assignment
> >> >>> Any idea how to fix this issue so I don't have to manually create
> the
> >> >>> GeoFence rules? And also, not have `geonode updatelayers` mess up
> the
> >> >>> rules
> >> >>> already created?
> >> >>> Cheers
> >> >>> Daniel
> >> >>> [1] -
> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
> >> >> _______________________________________________
> >> >> geonode-users mailing list
> >> >> geonode-users at lists.osgeo.org
> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> >> > Paolo Corti
> >> > Geospatial software developer
> >> > web: http://www.paolocorti.net
> >> > twitter: @capooti
> >> > skype: capooti
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180306/8e30ebf9/attachment.html>
More information about the geonode-users mailing list
