[GeoNode-users] error using geonode python manage.py updatelayers
Franklin, Chris - Perth. CFranklin at rml.com.au
Tue Mar 6 17:42:21 PST 2018
I have check that and it’s not the default style for that layer
[cid:image001.png at 01D3B5F8.9606C7E0]
From: Daniel Victoria [mailto:daniel.victoria at gmail.com]
Sent: Tuesday, 6 March 2018 7:55 PM
To: Franklin, Chris - Perth. <CFranklin at rml.com.au>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] error using geonode python manage.py updatelayers
Maybe your default style for that layer is set to the wrong one. Did you check what is the default style for that layer in GeoServer?
On Tue, Mar 6, 2018 at 2:54 AM Franklin, Chris - Perth. <CFranklin at rml.com.au<mailto:CFranklin at rml.com.au>> wrote:
Im running Geonode 2.4 on windows 2012 r2, I now get this error message when running the python manage.py updatelayers
(geonode-2.4.x) C:\GeoNode-2.4.x\geonode-2.4.x>python manage.py updatelayers
[updated] Layer Basemaps_Bibiani_50cm_z30n_UTM_WGS84_CIR-2018-02-23.ERS (1/46)
[updated] Layer Basemaps_Bibiani_50cm_z30n_UTM_WGS84_RGB-2018-02-23.ERS (2/46)
[updated] Layer RAV_ENV_locations (3/46)
[updated] Layer a__1290linesNEW (4/46)
[updated] Layer Boscut_Area_Plan (5/46)
Stopping process because --ignore-errors was not set and an error was found.
  File "manage.py", line 28, in <module>
    execute_from_command_line(sys.argv)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\core\management\
__init__.py", line 399, in execute_from_command_line
    utility.execute()
__init__.py", line 392, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
base.py", line 242, in run_from_argv
    self.execute(*args, **options.__dict__)
base.py", line 285, in execute
    output = self.handle(*args, **options)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\geonode\geoserver\management\commands\upd
atelayers.py", line 108, in handle
    remove_deleted=remove_deleted)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\geonode\geoserver\helpers.py", line 458,
in gs_slurp
    "bbox_y1": Decimal(resource.latlon_bbox[3])
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\manage
r.py", line 154, in get_or_create
    return self.get_queryset().get_or_create(**kwargs)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\modeltranslation\manage
r.py", line 341, in get_or_create
    return super(MultilingualQuerySet, self).get_or_create(**kwargs)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\query.
py", line 383, in get_or_create
    obj.save(force_insert=True, using=self.db)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\polymorphic\polymorphic
_model.py", line 90, in save
    return super(PolymorphicModel, self).save(*args, **kwargs)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\base.p
y", line 545, in save
    force_update=force_update, update_fields=update_fields)
y", line 582, in save_base
    update_fields=update_fields, raw=raw, using=using)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\dispatch\dispatc
her.py", line 185, in send
    response = receiver(signal=self, sender=sender, **named)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\geonode\geoserver\signals.py", line 470,
in geoserver_post_save
    set_styles(instance, gs_catalog)
  File "C:\GeoNode-2.4.x\geonode-2.4.x\geonode\geoserver\helpers.py", line 776,
in set_styles
    default_style = gs_layer.default_style
Exception: ('Failed to process boxcut_des201802_3d_decline_line', AttributeError
("'NoneType' object has no attribute 'default_style'",))
I don’t have a style called boxcut_des201802_3d_decline_line, but do have called boxcut_des201802_3d_decline_polyline, which I use on that layer, the layer work fine, but I can’t run the python manage.py updatelayers
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
  xmlns="http://www.opengis.net/sld" xmlns:ogc="http://www.opengis.net/ogc"
  xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <NamedLayer>
    <Name>boxcut_des201802_3d_decline_polyline</Name>
    <UserStyle>
      <Title>A violet line style</Title>
      <FeatureTypeStyle>
        <Rule>
          <Title>violet line</Title>
          <LineSymbolizer>
            <Stroke>
              <CssParameter name="stroke">#FF0000</CssParameter>
            </Stroke>
          </LineSymbolizer>
        </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
Can someone point me in the right direction?
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180307/3c6830fe/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180307/3c6830fe/attachment-0001.png>
More information about the geonode-users mailing list
