[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria daniel.victoria at gmail.com
Wed Mar 7 04:54:53 PST 2018
Thanks Alessio,
I had substituted "layer.alternate" to "layer.name" and sync_geofence
worked with no complains.  I also added a 5 second timeout between each
layer processing to try to bypass the problem mentioned by Paolo when
adding several rules to GeoFence.
However, each time I run sync_geofence I still get a different set of data
access rules in GeoFence. And I haven't figured out a pattern of which
layers are or not included in the rules.
Cheers
Daniel
On Wed, Mar 7, 2018 at 5:34 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> "alternate" attribute has been introduced on GeoNode 2.7+ with the update
> of pycsw.
> In the older versions you must use "typename" instead.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-03-06 17:26 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi Paolo,
>> I removed the try block. The error happens in the first print statement,
>> when it tries to print layer.alternate.
>> It says:
>> AttributeError: 'Layer' object has no attribute 'alternate'
>> I then removed the layer.alternate from the print statement and the
>> sync_geofence command runs. But each time I run it, I get a different
>> number of geofence data rules.
>> I'll try to run the commands in a python interpreter and try to identify
>> what's going on.
>> Cheers
>> On Tue, Mar 6, 2018 at 11:37 AM Paolo Corti <pcorti at gmail.com> wrote:
>>> Daniel
>>> remove the try block, and paste here the error trace stack
>>> ps: to debug with the shell, you must use "django-admin shell" command
>>> (which is "geonode shell" if you are using the Ubuntu package, I
>>> believe)
>>> thanks
>>> Paolo
>>> On Tue, Mar 6, 2018 at 7:11 AM, Daniel Victoria
>>> <daniel.victoria at gmail.com> wrote:
>>> > Hi Paolo,
>>> > There are 2 print statements in the except block. The first prints the
>>> error
>>> > and the second is the one that complains about the variable 'perm_spec'
>>> > referenced before assignment.
>>> > If I comment out just the second print statement I the following
>>> message
>>> > printed to the screen, one for each layer registered in GeoServer
>>> > ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>> > I tried to run the commands in a python interpreter to debug this. But
>>> I
>>> > could not get the environment set. When I import the
>>> geonode.layers.models
>>> > in the interpreter, it complains about django_settings_module.
>>> > Cheers
>>> > Daniel
>>> > On Mon, Mar 5, 2018 at 10:08 PM Paolo Corti <pcorti at gmail.com> wrote:
>>> >> Hi Daniel
>>> >> can you try to remove the line with the print statement and see what
>>> >> kind of error is raising?
>>> >> Paolo
>>> >> On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
>>> >> > Hi Paolo,
>>> >> > Thanks for the tip. However, I installed GeoNode from the APT
>>> repository
>>> >> > and
>>> >> > I have no idea how to upgrade GeoNode or change GeoFence store from
>>> H2
>>> >> > to
>>> >> > PostgreSQL.
>>> >> > I also added time.sleep(5) in sync_geofence.py, right before the try
>>> >> > block
>>> >> > but I'm still getting an error: It fails with the message:
>>> >> > Traceback (most recent call last):
>>> >> >   File "/usr/bin/django-admin", line 21, in <module>
>>> >> >     management.execute_from_command_line()
>>> >> >   File
>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>> >> > line
>>> >> > 354, in execute_from_command_line
>>> >> >     utility.execute()
>>> >> >   File
>>> >> > line
>>> >> > 346, in execute
>>> >> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>>> >> >   File
>>> >> > "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>> >> > line 394, in run_from_argv
>>> >> >     self.execute(*args, **cmd_options)
>>> >> >   File
>>> >> > line 445, in execute
>>> >> >     output = self.handle(*args, **options)
>>> >> >   File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
>>> >> > line 60, in handle
>>> >> >     print 'perm_spec is %s' % perm_spec
>>> >> > UnboundLocalError: local variable 'perm_spec' referenced before
>>> >> > assignment
>>> >> > Any other tips on how to fix this permission mess-up?
>>> >> > Thanks
>>> >> > Daniel
>>> >> > On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com>
>>> wrote:
>>> >> >> Another option could be to run a time.sleep for some seconds after
>>> >> >> each layer iteration in sync_geofence command
>>> >> >> cheers
>>> >> >> Paolo
>>> >> >> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com>
>>> wrote:
>>> >> >> > Hi Daniel
>>> >> >> > You seem to have hit this bug which I reported to GeoFence team
>>> in
>>> >> >> > the
>>> >> >> > past:
>>> >> >> > https://github.com/geoserver/geofence/issues/98
>>> >> >> > I didn't notice this happening in latest GeoFence version, so
>>> >> >> > upgrading to latest GeoNode could be an option.
>>> >> >> > Or you could try to use PostgreSQL instead than H2 as a GeoFence
>>> >> >> > store
>>> >> >> > hope this helps
>>> >> >> > cheers
>>> >> >> > Paolo
>>> >> >> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
>>> >> >> >> Update: Apparently, if I update the layer permissions in the web
>>> >> >> >> interface
>>> >> >> >> or if i run `geonode updatelayers -f <layer_name>`, the correct
>>> >> >> >> GeoFence
>>> >> >> >> permissions are created. Thus, doing so a layer at a time
>>> works. But
>>> >> >> >> several
>>> >> >> >> layers at once, no.
>>> >> >> >> What should I look for in the GeoServer log to try to figure out
>>> >> >> >> where
>>> >> >> >> the
>>> >> >> >> problem is occurring? I can attach the GeoServer log if that
>>> helps.
>>> >> >> >> Cheers
>>> >> >> >> Daniel
>>> >> >> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
>>> >> >> >> wrote:
>>> >> >> >>> Hi list,
>>> >> >> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine.
>>> >> >> >>> Right
>>> >> >> >>> now i
>>> >> >> >>> have 108 registered layers, some imported using the web
>>> interface,
>>> >> >> >>> some
>>> >> >> >>> using the `geonode importlayers` command.
>>> >> >> >>> Last week I noticed that some of the layers I was importing
>>> using
>>> >> >> >>> the
>>> >> >> >>> management command had view permission problems. I realized
>>> that
>>> >> >> >>> the
>>> >> >> >>> cause
>>> >> >> >>> was that the GeoFence rules were not being created correctly.
>>> >> >> >>> Looking at the messages on the list, I saw that there were some
>>> >> >> >>> discussions about this issue and that 1) there was a patch for
>>> >> >> >>> geoserver/helper.py [1] and 2) a new `sync_geofence` management
>>> >> >> >>> command.
>>> >> >> >>> I applied the patch and downloaded the `sync_geofence` command.
>>> >> >> >>> Now, every time I run `geonode updatelayers` I end up with a
>>> >> >> >>> different
>>> >> >> >>> set
>>> >> >> >>> of rules in GeoFence. Some times with 106 rules, some times
>>> with
>>> >> >> >>> 209
>>> >> >> >>> rules
>>> >> >> >>> etc. And I can't run `geonode sync_geofence` since I'm getting
>>> an
>>> >> >> >>> error:
>>> >> >> >>> assignment
>>> >> >> >>> Any idea how to fix this issue so I don't have to manually
>>> create
>>> >> >> >>> the
>>> >> >> >>> GeoFence rules? And also, not have `geonode updatelayers` mess
>>> up
>>> >> >> >>> the
>>> >> >> >>> rules
>>> >> >> >>> already created?
>>> >> >> >>> Cheers
>>> >> >> >>> Daniel
>>> >> >> >>> [1] -
>>> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
>>> >> >> >> _______________________________________________
>>> >> >> >> geonode-users mailing list
>>> >> >> >> geonode-users at lists.osgeo.org
>>> >> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> >> >> > Paolo Corti
>>> >> >> > Geospatial software developer
>>> >> >> > web: http://www.paolocorti.net
>>> >> >> > twitter: @capooti
>>> >> >> > skype: capooti
>>> >> >> Paolo Corti
>>> >> >> twitter: @capooti
>>> >> >> skype: capooti
>>> >> Paolo Corti
>>> >> twitter: @capooti
>>> >> skype: capooti
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180307/9c3a0eb7/attachment-0001.html>
More information about the geonode-users mailing list
