[GeoNode-users] Various issues GeoNode 2.6 and 2.8
Simone Dalmasso simone.dalmasso at gmail.com
Mon Mar 12 04:38:53 PDT 2018
Ciao Federico,
I think the owner and poc changes issues are known, we should already have
tickets for them.
For the layers visibility I see localhost/geoserver, in development mode
should be localhost:8080/geoserver while in production mode can be
servername/geoserver provided there's an apache/nginx proxy that makes that
possible. So probably your geonode settings for the OGC_SERVER are
incorrect.
Hope this helps
2018-03-09 10:17 GMT+01:00 Federico Gianoli <alpacagis at gmail.com>:
> Dear all,
> I have some issues with myGeoNode istances.
> Version 2.6.x
> I am not able to change the contactrole from the django Administration
> panel, (Admin > Base>Contact roles). I have the same issue on the 2.8rc11
> version. Could it be a problem with django permission?
> On the same version (2.6) it isn't possible to change the "owner" or the
> point of contact of a layer from the metadata form page, but I I have noted
> that in the 2.8rc11 version this issue was solved. Is it possible to port
> this fix in the previous version? If yes, where can I find the correct code?
> On the same 2.6 istance, I have a problem with the thumbnails generations.
> GeoNode creates only a white png for the layers. If I run "geonode
> updatelayers" the problem is not solved and I can not create the thumbnails
> manually.
> I read that this problem was solved on the new version, is it true?
> Do you suggest me to move to 2.8 in order to solve this?
> On the version 2.8rc11 I have an error with the map generation.
> I am not able to see any layer in a map
> If I do an inspect on the page I have these errors:
> Failed to load resource: net::ERR_CONNECTION_REFUSED
> wms:1 GET http://localhost/geoserver/wms?SERVICE=WMS&access_token=
> ri9yEX1YquZrz5yoo66lWz5hRUaDFr&&LAYERS=geonode%3Alabels&
> FORMAT=image%2Fpng&TRANSPARENT=TRUE&VERSION=1.1.1&REQUEST=GetMap&STYLES=&
> TILED=true&SRS=EPSG%3A900913&BBOX=5009377.085,3757032.
> 81375,6261721.35625,5009377.085&WIDTH=256&HEIGHT=256
> But I see the layer correctly from the layer view...
> Where am I doing wrong?
> Someone had the same issue?
> Thanks a lot
> Fede
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180312/e3c2eb76/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180312/e3c2eb76/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180312/e3c2eb76/attachment-0003.png>
More information about the geonode-users mailing list
