[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria daniel.victoria at gmail.com
Fri Mar 16 04:47:16 PDT 2018
Hi Oliver,
Not that I know of. But from what I understood, this problem is fixed on
the newer GeoNode versions. Meanwhile, If you'd like I could share the code
I used. But it's quite an ugly hack. It works some times. Then I need to
manually create some rules and then run the code again until it stops
working. Rinse and repeat ... very ugly...
Cheers
On Thu, Mar 15, 2018 at 2:25 AM Olivier Dalang <olivier.dalang at gmail.com>
wrote:
> Hi !
> I'm having the same issue (I think). Is there an open issue on github for
> this ? (I found some other geofence related issues but not this one)
> Kind regards,
> Olivier
> On Fri, Mar 9, 2018 at 3:02 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> There's something odd about GeoFence that you need to know, if you want
>> to send an "*" for a service or user or something, you don't have to send
>> the character '*' via XML but you need to remove the XML node completely.
>> GeoFence in fact accepts '*' on the rule, but then it considers '*' not
>> as ALL but as something with name = '*'. So pay attention.
>> Another thing, fixed on 2.7.x+, is that you always need to send the
>> priority along with the rule, otherwhise GeoFence can simply ignore it.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-03-08 15:49 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> OK, I gave up in trying to find why my GeoFence / GeoServer / GeoNode
>>> was acting all crazy. Since I only needed WMS access to the layers, I fixed
>>> my problem in the most embarrassingly (and ugly) way possible.
>>> I wrote a python code that will get a list of layers using WMS
>>> GetCapabilities and the list of GeoFence Rules (both authenticated as the
>>> geoserver admin). I then look for layers that have no rules set and allow
>>> both WMS and GWC for each.
>>> Funny thins is that while creating the rules, all of a sudden it stops
>>> working (response 500 from the GeoFence post request). I then restart
>>> tomcat, create one rule manually and then my script will work again. Seems
>>> like GeoFence is chocking...
>>> For now it seems to be working. Just hope I don't break more things in
>>> the process :)
>>> Cheers
>>> Daniel
>>> On Wed, Mar 7, 2018 at 11:25 AM Alessio Fabiani <
>>>> The risk is very high.
>>>> Try to compare the one from 2.7.x branch with your one. Maybe they have
>>>> diverged less.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> 2018-03-07 15:22 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> I've seem that the geonode/security/models.py in the master branch is
>>>>> quite different from what I got installed using the apt-sources. The file
>>>>> from the 2.6.x branch also differs from what I've got. Can I pull the
>>>>> security/models.py from the 2.6.x branch into my APT installation? Or do I
>>>>> risk messing things up even more?
>>>>> On Wed, Mar 7, 2018 at 10:55 AM Alessio Fabiani <
>>>>>> Uhm that's strange, from what I see on the code it should be the same
>>>>>> that updating permissions from the gui.
>>>>>> print 'Synchronizing permissions for layer %s/%s: %s' % (count,
>>>>>> layers_count, layer.alternate)
>>>>>> perm_spec = json.loads(_perms_info_json(layer))
>>>>>> layer.set_permissions(perm_spec)
>>>>>> it's possible that the old geofence methods have some bugs. There
>>>>>> were a lot or fixes since 2.6.3 version there also.
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> 2018-03-07 13:54 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com
>>>>>>> Thanks Alessio,
>>>>>>> I had substituted "layer.alternate" to "layer.name" and
>>>>>>> sync_geofence worked with no complains.  I also added a 5 second timeout
>>>>>>> between each layer processing to try to bypass the problem mentioned by
>>>>>>> Paolo when adding several rules to GeoFence.
>>>>>>> However, each time I run sync_geofence I still get a different set
>>>>>>> of data access rules in GeoFence. And I haven't figured out a pattern of
>>>>>>> which layers are or not included in the rules.
>>>>>>> Cheers
>>>>>>> Daniel
>>>>>>> On Wed, Mar 7, 2018 at 5:34 AM Alessio Fabiani <
>>>>>>>> Dear all,
>>>>>>>> "alternate" attribute has been introduced on GeoNode 2.7+ with the
>>>>>>>> update of pycsw.
>>>>>>>> In the older versions you must use "typename" instead.
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> 2018-03-06 17:26 GMT+01:00 Daniel Victoria <
>>>>>>>>> Hi Paolo,
>>>>>>>>> I removed the try block. The error happens in the first print
>>>>>>>>> statement, when it tries to print layer.alternate.
>>>>>>>>> It says:
>>>>>>>>> AttributeError: 'Layer' object has no attribute 'alternate'
>>>>>>>>> I then removed the layer.alternate from the print statement and
>>>>>>>>> the sync_geofence command runs. But each time I run it, I get a different
>>>>>>>>> number of geofence data rules.
>>>>>>>>> I'll try to run the commands in a python interpreter and try to
>>>>>>>>> identify what's going on.
>>>>>>>>> Cheers
>>>>>>>>> On Tue, Mar 6, 2018 at 11:37 AM Paolo Corti <pcorti at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Daniel
>>>>>>>>>> remove the try block, and paste here the error trace stack
>>>>>>>>>> ps: to debug with the shell, you must use "django-admin shell"
>>>>>>>>>> command
>>>>>>>>>> (which is "geonode shell" if you are using the Ubuntu package, I
>>>>>>>>>> believe)
>>>>>>>>>> thanks
>>>>>>>>>> Paolo
>>>>>>>>>> On Tue, Mar 6, 2018 at 7:11 AM, Daniel Victoria
>>>>>>>>>> <daniel.victoria at gmail.com> wrote:
>>>>>>>>>> > Hi Paolo,
>>>>>>>>>> > There are 2 print statements in the except block. The first
>>>>>>>>>> prints the error
>>>>>>>>>> > and the second is the one that complains about the variable
>>>>>>>>>> 'perm_spec'
>>>>>>>>>> > referenced before assignment.
>>>>>>>>>> > If I comment out just the second print statement I the
>>>>>>>>>> following message
>>>>>>>>>> > printed to the screen, one for each layer registered in
>>>>>>>>>> GeoServer
>>>>>>>>>> > ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>>>>>>>>> > I tried to run the commands in a python interpreter to debug
>>>>>>>>>> this. But I
>>>>>>>>>> > could not get the environment set. When I import the
>>>>>>>>>> geonode.layers.models
>>>>>>>>>> > in the interpreter, it complains about django_settings_module.
>>>>>>>>>> > Cheers
>>>>>>>>>> > Daniel
>>>>>>>>>> > On Mon, Mar 5, 2018 at 10:08 PM Paolo Corti <pcorti at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>> >> Hi Daniel
>>>>>>>>>> >> can you try to remove the line with the print statement and
>>>>>>>>>> see what
>>>>>>>>>> >> kind of error is raising?
>>>>>>>>>> >> Paolo
>>>>>>>>>> >> On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
>>>>>>>>>> >> > Hi Paolo,
>>>>>>>>>> >> > Thanks for the tip. However, I installed GeoNode from the
>>>>>>>>>> APT repository
>>>>>>>>>> >> > and
>>>>>>>>>> >> > I have no idea how to upgrade GeoNode or change GeoFence
>>>>>>>>>> store from H2
>>>>>>>>>> >> > to
>>>>>>>>>> >> > PostgreSQL.
>>>>>>>>>> >> > I also added time.sleep(5) in sync_geofence.py, right before
>>>>>>>>>> the try
>>>>>>>>>> >> > block
>>>>>>>>>> >> > but I'm still getting an error: It fails with the message:
>>>>>>>>>> >> > Traceback (most recent call last):
>>>>>>>>>> >> >   File "/usr/bin/django-admin", line 21, in <module>
>>>>>>>>>> >> >     management.execute_from_command_line()
>>>>>>>>>> >> >   File
>>>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>>>>>>> >> > line
>>>>>>>>>> >> > 354, in execute_from_command_line
>>>>>>>>>> >> >     utility.execute()
>>>>>>>>>> >> >   File
>>>>>>>>>> >> > line
>>>>>>>>>> >> > 346, in execute
>>>>>>>>>> >> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>>> >> >   File
>>>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>>>>>> >> > line 394, in run_from_argv
>>>>>>>>>> >> >     self.execute(*args, **cmd_options)
>>>>>>>>>> >> >   File
>>>>>>>>>> >> > line 445, in execute
>>>>>>>>>> >> >     output = self.handle(*args, **options)
>>>>>>>>>> >> >   File
>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
>>>>>>>>>> >> > line 60, in handle
>>>>>>>>>> >> >     print 'perm_spec is %s' % perm_spec
>>>>>>>>>> >> > UnboundLocalError: local variable 'perm_spec' referenced
>>>>>>>>>> before
>>>>>>>>>> >> > assignment
>>>>>>>>>> >> > Any other tips on how to fix this permission mess-up?
>>>>>>>>>> >> > Thanks
>>>>>>>>>> >> > Daniel
>>>>>>>>>> >> > On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <
>>>>>>>>>> pcorti at gmail.com> wrote:
>>>>>>>>>> >> >> Another option could be to run a time.sleep for some
>>>>>>>>>> seconds after
>>>>>>>>>> >> >> each layer iteration in sync_geofence command
>>>>>>>>>> >> >> cheers
>>>>>>>>>> >> >> Paolo
>>>>>>>>>> >> >> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <
>>>>>>>>>> >> >> > Hi Daniel
>>>>>>>>>> >> >> > You seem to have hit this bug which I reported to
>>>>>>>>>> GeoFence team in
>>>>>>>>>> >> >> > the
>>>>>>>>>> >> >> > past:
>>>>>>>>>> >> >> > https://github.com/geoserver/geofence/issues/98
>>>>>>>>>> >> >> > I didn't notice this happening in latest GeoFence
>>>>>>>>>> version, so
>>>>>>>>>> >> >> > upgrading to latest GeoNode could be an option.
>>>>>>>>>> >> >> > Or you could try to use PostgreSQL instead than H2 as a
>>>>>>>>>> GeoFence
>>>>>>>>>> >> >> > store
>>>>>>>>>> >> >> > hope this helps
>>>>>>>>>> >> >> > cheers
>>>>>>>>>> >> >> > Paolo
>>>>>>>>>> >> >> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
>>>>>>>>>> >> >> >> Update: Apparently, if I update the layer permissions in
>>>>>>>>>> the web
>>>>>>>>>> >> >> >> interface
>>>>>>>>>> >> >> >> or if i run `geonode updatelayers -f <layer_name>`, the
>>>>>>>>>> correct
>>>>>>>>>> >> >> >> GeoFence
>>>>>>>>>> >> >> >> permissions are created. Thus, doing so a layer at a
>>>>>>>>>> time works. But
>>>>>>>>>> >> >> >> several
>>>>>>>>>> >> >> >> layers at once, no.
>>>>>>>>>> >> >> >> What should I look for in the GeoServer log to try to
>>>>>>>>>> figure out
>>>>>>>>>> >> >> >> where
>>>>>>>>>> >> >> >> the
>>>>>>>>>> >> >> >> problem is occurring? I can attach the GeoServer log if
>>>>>>>>>> that helps.
>>>>>>>>>> >> >> >> Cheers
>>>>>>>>>> >> >> >> Daniel
>>>>>>>>>> >> >> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
>>>>>>>>>> >> >> >> wrote:
>>>>>>>>>> >> >> >>> Hi list,
>>>>>>>>>> >> >> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu
>>>>>>>>>> machine.
>>>>>>>>>> >> >> >>> Right
>>>>>>>>>> >> >> >>> now i
>>>>>>>>>> >> >> >>> have 108 registered layers, some imported using the web
>>>>>>>>>> interface,
>>>>>>>>>> >> >> >>> some
>>>>>>>>>> >> >> >>> using the `geonode importlayers` command.
>>>>>>>>>> >> >> >>> Last week I noticed that some of the layers I was
>>>>>>>>>> importing using
>>>>>>>>>> >> >> >>> the
>>>>>>>>>> >> >> >>> management command had view permission problems. I
>>>>>>>>>> realized that
>>>>>>>>>> >> >> >>> the
>>>>>>>>>> >> >> >>> cause
>>>>>>>>>> >> >> >>> was that the GeoFence rules were not being created
>>>>>>>>>> correctly.
>>>>>>>>>> >> >> >>> Looking at the messages on the list, I saw that there
>>>>>>>>>> were some
>>>>>>>>>> >> >> >>> discussions about this issue and that 1) there was a
>>>>>>>>>> patch for
>>>>>>>>>> >> >> >>> geoserver/helper.py [1] and 2) a new `sync_geofence`
>>>>>>>>>> management
>>>>>>>>>> >> >> >>> command.
>>>>>>>>>> >> >> >>> I applied the patch and downloaded the `sync_geofence`
>>>>>>>>>> command.
>>>>>>>>>> >> >> >>> Now, every time I run `geonode updatelayers` I end up
>>>>>>>>>> with a
>>>>>>>>>> >> >> >>> different
>>>>>>>>>> >> >> >>> set
>>>>>>>>>> >> >> >>> of rules in GeoFence. Some times with 106 rules, some
>>>>>>>>>> times with
>>>>>>>>>> >> >> >>> 209
>>>>>>>>>> >> >> >>> rules
>>>>>>>>>> >> >> >>> etc. And I can't run `geonode sync_geofence` since I'm
>>>>>>>>>> getting an
>>>>>>>>>> >> >> >>> error:
>>>>>>>>>> referenced before
>>>>>>>>>> >> >> >>> assignment
>>>>>>>>>> >> >> >>> Any idea how to fix this issue so I don't have to
>>>>>>>>>> manually create
>>>>>>>>>> >> >> >>> the
>>>>>>>>>> >> >> >>> GeoFence rules? And also, not have `geonode
>>>>>>>>>> updatelayers` mess up
>>>>>>>>>> >> >> >>> the
>>>>>>>>>> >> >> >>> rules
>>>>>>>>>> >> >> >>> already created?
>>>>>>>>>> >> >> >>> Cheers
>>>>>>>>>> >> >> >>> Daniel
>>>>>>>>>> >> >> >>> [1] -
>>>>>>>>>> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
>>>>>>>>>> >> >> >> _______________________________________________
>>>>>>>>>> >> >> >> geonode-users mailing list
>>>>>>>>>> >> >> >> geonode-users at lists.osgeo.org
>>>>>>>>>> >> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> >> >> > Paolo Corti
>>>>>>>>>> >> >> > Geospatial software developer
>>>>>>>>>> >> >> > web: http://www.paolocorti.net
>>>>>>>>>> >> >> > twitter: @capooti
>>>>>>>>>> >> >> > skype: capooti
>>>>>>>>>> >> >> Paolo Corti
>>>>>>>>>> >> >> twitter: @capooti
>>>>>>>>>> >> >> skype: capooti
>>>>>>>>>> >> Paolo Corti
>>>>>>>>>> >> twitter: @capooti
>>>>>>>>>> >> skype: capooti
>>>>>>>>>> Paolo Corti
>>>>>>>>>> twitter: @capooti
>>>>>>>>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180316/24797e2c/attachment-0001.html>
More information about the geonode-users mailing list
