[GeoNode-users] Geonode Installation migrate and collectstatic
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon May 7 09:03:20 PDT 2018
Hi Simone Dalmasso and Paolo Corti,
I forgot to mention that I am following this tutorial (
http://docs.geonode.org/en/master/tutorials/install_and_
admin/geonode_install/setup_configure_httpd.html). And the incoherence I
found in the local_settings.py configuration is in OGC_SERVER settings: <
'LOG_FILE': '%s/geoserver/data/logs/geoserver.log' % os.path.abspath(os.path
.join(*PROJECT_ROOT*, os.pardir)),>
The *PROJECT_ROOT* was changed to *LOCAL_ROOT*.
However I still having the same issue while running python manage.py
migrate and python manage.py collectstatic
  File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File "/root/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
line 328, in execute
    django.setup()
  File "/root/Envs/geonode/local/lib/python2.7/site-packages/django/__init__.py",
line 18, in setup
    apps.populate(settings.INSTALLED_APPS)
  File "/root/Envs/geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
line 89, in populate
    "duplicates: %s" % app_config.label)
django.core.exceptions.ImproperlyConfigured: Application labels aren't
unique, duplicates: ows_api
Lastly, the configuration below is in the end of my local_settings lines
559 and 562 and I am not sure if the INSTALLED_APPS in line 559 is related
to REACT based Client (Line 322) or to MapStore2 based Client (Line 331).
INSTALLED_APPS = INSTALLED_APPS + ('my_geonode',)
TEMPLATES[0]['DIRS'].insert(0, os.path.join(LOCAL_ROOT, "templates"))
Thank you for your time in advance.
Kind regards
Julierme
2018-05-04 17:05 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Yes, I think my issue could be related to the INSTALLED_APPS variable.
> Though I do not have line 348 <INSTALLED_APPS += ('geonode.contrib.ows_api
> ',)> in the local_settings.py.
> Passing a magnifying glass in the local_settings.py, I found the following
> INSTALLED_APPS:
> *Line 99* < INSTALLED_APPS += (NOTIFICATIONS_MODULE, )>
> NOTIFICATION_ENABLED is set to *FALSE, *so I think the IF is not executed
> *Line 322* < # INSTALLED_APPS += ('geonode-client', )>
> INSTALLED_APPS is commented out.
> *Line 331* <# INSTALLED_APPS += ('geonode_mapstore_client', )>
> *Line 412* <# if 'geonode.geoserver' in INSTALLED_APPS:>
> *Line 517* < if 'geonode.contrib.monitoring' not in INSTALLED_APPS:>
> MONITORING_ENABLED is set to *TRUE in line 516, *so I think the IF is
> executed in *line 517* and *line 518* is executed too.
> *Line 559* <INSTALLED_APPS = INSTALLED_APPS + ('my_geonode',)>
> I got very confused in this local_settings file. I wonder if I can set *line
> 559* before *line 517 *in order to fix the problem. Could you give me a
> clue on what is going wrong, please? I am also sending the
> local_settings.py in attached.
> Thank you for your time and patience in advance.
> I appreciated it
> Julierme
> 2018-05-04 13:05 GMT-03:00 Paolo Corti <pcorti at gmail.com>:
>> Hi Julierme
>> It looks like you are using the (recommended approach) of using a geonode
>> project.
>> This is caused by this line in geonode-project:
>> https://github.com/GeoNode/geonode-project/blob/2.8.0/projec
>> t_name/settings.py#L348
>> we will need to fix this, meanwhile you can remove that line in your
>> instance
>> best
>> Paolo
>> On Fri, May 4, 2018 at 4:52 AM Simone Dalmasso <simone.dalmasso at gmail.com
>> wrote:
>> > Hi, check if in your settings.INSTALLED_APPS you have the
>> 'geonode.contrib.ows_api' declared just once.
>> > Hope this helps
>> > 2018-05-03 22:20 GMT+02:00 Julierme Pinheiro <
>> >> Hi all,
>> >> I am installing geonode 2.8.0 in an Ubuntu 16.04 machine following the
>> installation guide in here. And I wonder if anybody has faced any issue
>> with $ python manage.py migrate and $ python manage.py collectstatic as I
>> have in:
>> >>    File
>> >>      utility.execute()
>> >>    File
>> >>      django.setup()
>> >>    File
>> /__init__.py",
>> line 18, in setup
>> >>    File
>> /apps/registry.py",
>> >>    File
>> >>      utility.execute()
>> >>    File
>> >>      django.setup()
>> >>    File
>> /__init__.py",
>> line 18, in setup
>> >>    File
>> /apps/registry.py",
>> >> Thank you very much for your time and help in advance.
>> >> Kind regards
>> >> Julierme
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> > Simone
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180507/f2031d36/attachment.html>
More information about the geonode-users mailing list
