[GeoNode-users] Geonode Installation Ubuntu 16.04 - geonodeAuthProvider and Start-up log
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Tue May 8 12:13:43 PDT 2018
Hi all,
I am about to finish geonode installation and at this stage following the
tutorial in here:
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html
I could not find the subdirectory "geonodeAuthProvider" in auth directory.
I have "default" and "geofence" subdirectories in auth directory and both
subdirectories have a  config.xml that does not have <baseUrl>
http://localhost/</baseUrl>
This configuration is found in* step 3*
Edit /data/geoserver-data/security/auth/geonodeAuthProvider/config.xml with
a text editor
Also, after running
sudo tail -F -n 300 /var/lib/tomcat8/logs/catalina.out
I got the following error in the start-up logs:
ERROR StatusLogger Log4j2 could not find a logging implementation. Please
add log4j-core to the classpath. Using SimpleLogger to log to the console...
Is there any update in step 3 and could you give me a clue on how to fix
the error showed in the start-up log?
Thank you for your time in advance
Best regards
Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180508/08730203/attachment.html>
More information about the geonode-users mailing list
