[GeoNode-users] [GeoNode-devel] Geonode Unable to Sign in
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed May 9 15:10:49 PDT 2018
The response is the same to python manage.py shell
I have no idea about what is going on. Any help on that would be very
appreciated.
Thank you very much for your help and time.
Kind regards
2018-05-09 18:58 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Hi Faneva,
> I have tried all these commands:
> python manage.py createsuperuser
> python manage.py changepassword admin
> And the response to both is:
> Traceback (most recent call last):
>   File "manage.py", line 31, in <module>
>     execute_from_command_line(sys.argv)
>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
> line 303, in execute
>     settings.INSTALLED_APPS
>   File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py",
> line 48, in __getattr__
>     self._setup(name)
> line 44, in _setup
>     self._wrapped = Settings(settings_module)
> line 92, in __init__
>     mod = importlib.import_module(self.SETTINGS_MODULE)
>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> import_module
>     __import__(name)
>   File "/home/geonode/my_geonode/my_geonode/settings.py", line 27, in
> <module>
>     from geonode.settings import *
> ImportError: No module named geonode.settings
> I have no idea in what is going on. Any help on that would be very
> appreciated.
> Kind regards
> Julierme
> 2018-05-09 18:50 GMT-03:00 ANDRIAMIADANTSOA Fanevanjanahary <
> fanevanjanahary at gmail.com>:
>> Hello Julierme,
>> Did you already try to change the admin's password?
>> This is commande to change this
>> Best regards
>> Faneva
>> On Thu, May 10, 2018, 00:21 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> wrote:
>>> Hi all,
>>> I finally got the end of the geonode installation as in here:
>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>> n/geonode_install/all_together.html
>>> But now, I am unable to sign in. The tutorial says: Login with admin
>>> username and password you just set. But I do not remember setting an
>>> username and a password during the installation. I tried the default one:
>>> username:admin and password: admin, but I got no success.
>>> Any help on that please?
>>> Thank you for your time in advance.
>>> Best regards
>>> Julierme
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180509/5f920bec/attachment.html>
More information about the geonode-users mailing list
