[GeoNode-users] Preferred installation for production
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue May 15 02:20:02 PDT 2018
Hello Annalisa,
recently the preferred way is to use Docker Compose method.
The setup through ppa can also work but there are currently a couple of
things to be aware of:
1. It will install the stable release not the most updated. That means that
recent fixes won't be included there
2. Currently the debian package is not able to just "update" the GeoNode
packages. It always needs to be installed on a clean Ubuntu machine.
For the reasons above, I would proceed with this method
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
and of course, when everything has been setup, change the default passwords
and put DEBUG = False on settings.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-05-14 11:32 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Hi all,
> we have a working geonode 2.4 in production on ubuntu 16.04. Now we want
> to move to 2.8. What is the  preferred  installation method ? New server
> (always ubuntu 16.04) will going to replace current server.
> The* old *geonode was installed via apt-get :
> sudo add-apt-repository ppa:geonode/stable
> sudo apt-get update
> sudo apt-get install geonode
> Then I had installed geonode-project for a few changes in logos, colors
> and so on:
> django-admin startproject geoportale20 --template=https://github.com/
> GeoNode/geonode-project/archive/master.zip -epy,rst
> sudo pip install -e geoportale20
> Now I can install 2.8 version on a clean ubuntu 16.04 with :
> sudo apt-add-repository ppa:geonode/stable
> sudo apt update -y
> sudo apt upgrade -y
> sudo apt install geonode
> How do you suggest to install geonode-project ?
> I've read of  virtualenv  but I don't have experience on it and I need
> geonode for production!
> Thanks,
> Annalisa
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/9bca674f/attachment-0001.html>
More information about the geonode-users mailing list
