[GeoNode-users] Leaflet settings
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue May 15 03:08:19 PDT 2018
Hi Stefano,
from what you are saying I guess the problem is on your network then, maybe
some firewall preventing you to load https osm tiles.
I currently can access those tiles without problems
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-05-15 11:58 GMT+02:00 <Stefano.LUONI at ext.ec.europa.eu>:
> Hi Alessio,
> well, actually my installation in version 2.7.5 and doesn't have any of
> the settings you're talking about; I guess they were introduced later. I
> created a Django project based on template on geonode-project Github
> repository, so Geonode itself is a requirement of the project and the
> source code is into my virtual environment. These settings are not listed
> in Geonode settings file, nor in my project settings file.
> Having said that, I'm not sure on how to proceed, also because I'm
> currently not able of performing a new installation, since I get broken
> dependencies issues, like so:
> *django-haystack 2.8.0 has requirement Django>=1.11, but you'll have
> django 1.8.19 which is incompatible.*
> *docker 3.1.1 has requirement requests!=2.18.0,>=2.14.2, but you'll have
> requests 2.11.1 which is incompatible.*
> *pycsw 2.0.3 has requirement OWSLib==0.10.3, but you'll have owslib 0.15.0
> *pycsw 2.0.3 has requirement pyproj==1.9.3, but you'll have pyproj 1.9.5.1
> *pycsw 2.0.3 has requirement Shapely==1.3.1, but you'll have shapely
> 1.5.17 which is incompatible.*
> *flake8 2.5.4 has requirement pyflakes<1.1,>=0.8.1, but you'll have
> pyflakes 1.2.3 which is incompatible.*
> I Think I could have the same issue that exists on the website
> http://disasterrisk.af/http://disasterrisk.af/ where tiles are not loded
> in layer pages, nor in Risk Management Tools pages.
> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
> *Sent:* 15 May 2018 11:32
> *To:* LUONI Stefano (JRC-ISPRA-EXT)
> *Cc:* Alessio Fabiani; geonode-users
> *Subject:* Re: [GeoNode-users] Leaflet settings
> Hi Stefano,
> I just started doing some tests with Leaflet. Did not taken a look at the
> background layers configuration yet.
> First of all
> On settings.py (or local_settings.py) in order to enable the Leaflet
> client library you now have to change the following ones
> # Default preview library
> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'leaflet'  # DEPRECATED use
> HOOKSET instead
> GEONODE_CLIENT_HOOKSET = "geonode.client.hooksets.LeafletHookSet"
> Secondly
> I noticed that the Layer Details view works fine
> but the Map Composer has some issues.
> Can you please describe in details your use case?
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-05-14 16:57 GMT+02:00 <Stefano.LUONI at ext.ec.europa.eu>:
>> Hi Alessio,
>> I have a bunch of errors where Leaflet is marked as initiatior of request
>> (see attachment). This is from a page in a custom Geonode project; however,
>> tiles are not loading in Geonode layer pages too.
>> Thanks,
>> Stefano
>> *Sent:* 14 May 2018 16:35
>> *Cc:* geonode-users
>> So, in GeoNode 2.7 the Javascript context of the map is a bit different
>> from the precious versions. It contains more informations about layer
>> projection and temporal dimension.
>> Most probably the old Leaflet JS map configuration is no more able to
>> find the layer configurations from the new-style json.
>> I'll try to take a look at this. In the meantime, can you confirm that
>> you have a bunch of Javascript errors when trying to load the Leaflet
>> viewer?
>> Regards,
>> Alessio Fabiani
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D%0A+55054++Massarosa&entry=gmail&source=g>
>> 55054
>>  Massarosa
>> (LU)
>> Italy
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> 2018-05-14 16:21 GMT+02:00 <Stefano.LUONI at ext.ec.europa.eu>:
>>> Hi everyone,
>>> map tiles suddenly stopped loading on my Geonode installation (2.7); the
>>> urls generated by Leaflet are like *https://c.tile.openstreetmap.org/3/3/2.png
>>> <https://c.tile.openstreetmap.org/3/3/2.png>* and simply won't load.
>>> When I first installed Geonode I left all map and layers settings as
>>> default and everything worked. Can you address me on how I'm supposed to
>>> configure Geonode's Leaflet to use another layer provider, such as Mapbox,
>>> or do you have different suggestions to solve my issue?
>>> Thanks,
>>> Stefano
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/abd39f17/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/abd39f17/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/abd39f17/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180515/abd39f17/attachment-0005.png>
More information about the geonode-users mailing list
