[GeoNode-users] Geoserver fails to startup using docker-compose
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu May 17 02:10:32 PDT 2018
Need to test locally.
That's strange though, I tested it a couple of days ago and I could access
to it.
Will try to give you feedbacks asap.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-05-17 11:03 GMT+02:00 admire <addloe at gmail.com>:
> Hi
> On 17/05/2018 10:57, Alessio Fabiani wrote:
> Hello,
> by using docker-compose, as far as I know, the services are not mapper to
> "localhost" but to a specific IP address.
> Geonode starts up and I am able to access it from http://geonode  but
> when I access http://geonode/geoserver/ I get a 404 error which shows me
> that somehow Geoserver is not up. That why I had to log into the container
> and run a curl request with localhost.
> Regards
> Regards,
> Alessio Fabiani
> == GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
> @alfa7691 Founder/Technical Lead
> GeoSolutions S.A.S. Via di Montramito 3/A 55054  Massarosa (LU) Italy phone:
> +39 0584 962313 fax:     +39 0584 1660272 mob:   +39 331 6233686
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-05-17 10:55 GMT+02:00 admire <addloe at gmail.com>:
>> Hi
>> I have checked out geonode 2.8.0 source code and have been trying to get
>> my local environment running  using docker-compose but have been
>> unsuccessful.  Geonode starts up nicely but it seems Geoserver is not up as
>> I fail to upload layers.
>> I tried to bring up the services using docker-compose up -d and then make
>> sync
>> I have logged into the geoserver4geonode container and I cannot even run
>> a curl request.
>> curl -v -u admin:geoserver -XGET http://localhost:8080/geoserve
>> r/rest/security/masterpw.xml
>> I get the error
>> ://localhost:8080/geoserver/rest/security/masterpw.xmlmin:geoserver
>> -XGET   http:
>> Note: Unnecessary use of -X or --request, GET is already inferred.
>> *   Trying 127.0.0.1...
>> * TCP_NODELAY set
>> * Connected to localhost (127.0.0.1) port 8080 (#0)
>> * Server auth using Basic with user 'admin'
>> > GET /geoserver/rest/security/masterpw.xml HTTP/1.1
>> > Host: localhost:8080
>> > Authorization: Basic YWRtaW46Z2Vvc2VydmVy
>> > User-Agent: curl/7.52.1
>> > Accept: */*
>> < HTTP/1.1 404
>> < Content-Type: text/html;charset=utf-8
>> < Content-Language: en
>> < Content-Length: 1121
>> < Date: Thu, 17 May 2018 08:52:01 GMT
>> I also have tailed the logs for geoserver4geonode container and see that
>> tomcat starts up without any problem.
>> Regards
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/9ec6dd31/attachment-0001.html>
More information about the geonode-users mailing list
