[GeoNode-users] Geonode-Project: Apache Config / geonode.conf
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu May 17 11:30:16 PDT 2018
Hi Francesco,
Thank you for your questions. I added tabs and text change to geonode-dev
(geonode-dev.png) and I can see the changes over geonode-production
(geonode-production.png). However If I keep WSGIDaemonProcess my_geonode
python-path=/home/my_geonode/my_geonode:/home/geo/Envs/my_geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2
I can see the changes done through geonode-dev css and site_base.html and
site_index.html over the geonode-production, But geonode-production uses
geonode-dev within this python-path config.
However if I keep WSGIDaemonProcess geonode
python-path=/home/geonode/my_geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages
I can see the changes done through geonode-dev css and not the changes in
site_base.html and site_index.html. But geonode-productions is using its
right database.
Could you give a clue in what is going on? I also following the directions
in here http://geonode.org/dev-workshop/#/8/3.
Thank you for your time in advance
Julierme
2018-05-17 13:16 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> Once you have installed GeoNode as a library/package in your my_geonode
> virtual environment did you see your custom text and tabs changes starting
> the development server? That means “python manage.py run server” ?
> Once you’ll get this achievement then the apache configuration will be
> easier.
> Hope this helps
> Francesco
> Il giorno 17/mag/2018, alle ore 18:01, Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear Framcesco,
> Thank you very much for your reply. I have gone through
> http://geonode.org/dev-workshop/#/ several times. It is a great source,
> but again this issue was related to geonode.conf /apache2 config.
> I got to fix this problem making changes to geonode.conf. In my case, if I
> have geonode production in /home/geonode and geonode-project in
> /home/my_geonode, the geonode.conf must have all information related to
> geonode-project, and I was still gathering information from
> geonode-production in geonode.conf.
> I appreciated your time and help.
> Kind regards
> Julierme
> 2018-05-17 12:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Dear Julierme,
>> I encourage you to follow scrupulously the developer workshop where
>> everything you are trying to do is well covered http://geonode.org/dev
>> -workshop/#/.
>> Francesco
>> Il giorno 17/mag/2018, alle ore 17:06, Julierme Pinheiro <
>> Dear all geonode developers,
>> I have made changes in my geonode production through geonode-project.
>> Just now, I realized that the geonode-project css config is being applied
>> to geonode production main page, however my new tabs and text change in
>> site_base.html and site.index.html are not being applied to geonode
>> production main page.
>> I ran the commands python manage.py migrate and python manage.py
>> collectstatic and realized that static_root was created in
>> /home/my_geonode/my_geonode/my_geoonde/static_root
>> geonode.conf Directories make reference to several paths
>> /home/my_geonode/my_geonode/my_geonode/uploaded/ and
>> /home/my_geonode/my_geonode/my_geonode/uploaded/* (group, people_group,
>> documents, Layers, avatars and thumbs)
>> but directory uploaded is no in /home/my_geonode/my_geonode/my_geoonode
>> I wonder if this directory <uploaded> and its subdirectories <group,
>> people_group, documents, Layers, avatars and thumbs> are added manually.
>> In order to see the new tabs and text changes in geonode production, I
>> also added another directory to geonode.conf
>>  <Directory "/home/my_geonode/my_geonode/my_geonode/templates/">
>>         Order allow,deny
>>         Options Indexes FollowSymLinks
>>         Allow from all
>>         Require all granted
>>         IndexOptions FancyIndexing
>>  </Directory>
>> The directory templates contains site_base.html and site_index.html. But
>> yet I could not see the new tabs in my geonode production main page.
>> Any help on that will be very appreciated.
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/fe05cb44/attachment.html>
More information about the geonode-users mailing list
