[GeoNode-users] Geonode-Project: Apache Config / geonode.conf
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu May 17 11:46:51 PDT 2018
Now to give a picture (geonode-production_noTabs_noTextchange.png in
attached) of what was saying:
However if I keep WSGIDaemonProcess geonode python-path=/home/geonode/my_
geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages user=www-data
threads=15 processes=2
I can see the changes done through geonode-dev css and not the changes in
site_base.html and site_index.html. But geonode-productions is using its
right database.
Note: In this case I have production database being used and css change,
but no site_base.html and site_index.html change according to geonode-dev.
best regards
Julierme
2018-05-17 15:33 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> making a correction in my previous e-mail.
> I can see the changes done through geonode-dev css and site_base.html and
> site_index.html over the geonode-production, But geonode-production uses
> geonode-dev database within this python-path config.
> Kind regards
> Julierme
> 2018-05-17 15:30 GMT-03:00 Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com>:
>>> Hi Francesco,
>>> Thank you for your questions. I added tabs and text change to
>>> geonode-dev (geonode-dev.png) and I can see the changes over
>>> geonode-production (geonode-production.png). However If I keep
>>> WSGIDaemonProcess my_geonode python-path=/home/my_geonode/m
>>> y_geonode:/home/geo/Envs/my_geonode/lib/python2.7/site-packages
>>> user=www-data threads=15 processes=2
>>> and site_index.html over the geonode-production, But geonode-production
>>> uses geonode-dev within this python-path config.
>>> python-path=/home/geonode/my_geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages
>>> in site_base.html and site_index.html. But geonode-productions is using its
>>> right database.
>>> Could you give a clue in what is going on? I also following the
>>> directions in here http://geonode.org/dev-workshop/#/8/3.
>>> Thank you for your time in advance
>>> Julierme
>>> 2018-05-17 13:16 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Once you have installed GeoNode as a library/package in your my_geonode
>>>> virtual environment did you see your custom text and tabs changes starting
>>>> the development server? That means “python manage.py run server” ?
>>>> Once you’ll get this achievement then the apache configuration will be
>>>> easier.
>>>> Hope this helps
>>>> Francesco
>>>> Il giorno 17/mag/2018, alle ore 18:01, Julierme Pinheiro <
>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>> Dear Framcesco,
>>>> Thank you very much for your reply. I have gone through
>>>> http://geonode.org/dev-workshop/#/ several times. It is a great
>>>> source, but again this issue was related to geonode.conf /apache2 config.
>>>> I got to fix this problem making changes to geonode.conf. In my case,
>>>> if I have geonode production in /home/geonode and geonode-project in
>>>> /home/my_geonode, the geonode.conf must have all information related to
>>>> geonode-project, and I was still gathering information from
>>>> geonode-production in geonode.conf.
>>>> I appreciated your time and help.
>>>> Kind regards
>>>> Julierme
>>>> 2018-05-17 12:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Dear Julierme,
>>>>> I encourage you to follow scrupulously the developer workshop where
>>>>> everything you are trying to do is well covered http://geonode.org/dev
>>>>> -workshop/#/.
>>>>> Francesco
>>>>> Il giorno 17/mag/2018, alle ore 17:06, Julierme Pinheiro <
>>>>> Dear all geonode developers,
>>>>> I have made changes in my geonode production through geonode-project.
>>>>> Just now, I realized that the geonode-project css config is being applied
>>>>> to geonode production main page, however my new tabs and text change in
>>>>> site_base.html and site.index.html are not being applied to geonode
>>>>> production main page.
>>>>> I ran the commands python manage.py migrate and python manage.py
>>>>> collectstatic and realized that static_root was created in
>>>>> /home/my_geonode/my_geonode/my_geoonde/static_root
>>>>> geonode.conf Directories make reference to several paths
>>>>> /home/my_geonode/my_geonode/my_geonode/uploaded/ and
>>>>> /home/my_geonode/my_geonode/my_geonode/uploaded/* (group,
>>>>> people_group, documents, Layers, avatars and thumbs)
>>>>> but directory uploaded is no in /home/my_geonode/my_geonode/my
>>>>> _geoonode
>>>>> I wonder if this directory <uploaded> and its subdirectories <group,
>>>>> people_group, documents, Layers, avatars and thumbs> are added manually.
>>>>> In order to see the new tabs and text changes in geonode production, I
>>>>> also added another directory to geonode.conf
>>>>>  <Directory "/home/my_geonode/my_geonode/my_geonode/templates/">
>>>>>         Order allow,deny
>>>>>         Options Indexes FollowSymLinks
>>>>>         Allow from all
>>>>>         Require all granted
>>>>>         IndexOptions FancyIndexing
>>>>>  </Directory>
>>>>> The directory templates contains site_base.html and site_index.html.
>>>>> But yet I could not see the new tabs in my geonode production main page.
>>>>> Any help on that will be very appreciated.
>>>>> Kind regards
>>>>> Julierme
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/8a0a1e87/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180517/8a0a1e87/attachment-0001.png>
More information about the geonode-users mailing list
