[GeoNode-users] [GeoNode-devel] GeoNode WorldMap client to be part of GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 30 23:08:45 PDT 2018
Great! Thanks Paolo
2018-05-30 21:20 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> I forgot to mention that this client extends the GeoNode serialization
> format. Therefore maps whic are created using the WorldMap client will not
> be compatible with the default GeoNode client. It should be simple anyway
> to write a Django command which converts maps back and forth
> best
> Paolo
> On Wed, May 30, 2018 at 3:14 PM Paolo Corti <pcorti at gmail.com> wrote:
> > Dear GeoNode users and developers
> > Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch (to
> > become GeoNode 2.8.1), which implements this GNIP [2]. This pull request
> > introduce the Harvard WorldMap contribute application in GeoNode.
> > You can have a full list of the features introduced from the application
> at
> > [2]. In brief this application introduce a new client, based on an
> improved
> > version of the GeoExplorer default client, with additional features such
> as:
> > * layer categories in table of contents
> > * layer graduated style editor
> > * a find place widget and layers gazetteer
> > * feature search
> > * map revisions
> > * URL permalink for maps
> > * layer search with Hypermap Registry (optional)
> > The application is optional and does not introduce any change in existing
> > GeoNode tables. If enabled, it will create a few new tables in GeoNode
> > database, which are needed in order for the application to work. You must
> > use PostgreSQL to use this application, and PostgreSQL will require the
> > PostGIS and dblink extensions.
> > The GNIP implementation is based on current GeoNode WorldMap source code
> > [3], and contains code committed by a number of GeoNode developers:
> > * Matt Bertrand
> > * Paolo Corti
> > * Wayner Barrios
> > * Jorge Martínez Gómez
> > * Lennin Suescun
> > * 刘尧 aka Lanni
> > If there is consensus, this application will be merged in GeoNode source
> > code as a contribute module.
> > Thanks
> > Paolo
> > [1] https://github.com/GeoNode/geonode/pull/3817
> > [2] https://github.com/GeoNode/geonode/issues/3718
> > [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180531/ba43950d/attachment.html>
More information about the geonode-users mailing list
