[GeoNode-users] [GeoNode-devel] GeoNode WorldMap client to be part of GeoNode
Dimitris Kar dkarakostis at gmail.com
Thu May 31 00:03:11 PDT 2018
Thanks Paolo,
Great contribution.
On Thu, May 31, 2018 at 8:08 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Great! Thanks Paolo
> 2018-05-30 21:20 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> I forgot to mention that this client extends the GeoNode serialization
>> format. Therefore maps whic are created using the WorldMap client will not
>> be compatible with the default GeoNode client. It should be simple anyway
>> to write a Django command which converts maps back and forth
>> best
>> Paolo
>> On Wed, May 30, 2018 at 3:14 PM Paolo Corti <pcorti at gmail.com> wrote:
>> > Dear GeoNode users and developers
>> > Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch (to
>> > become GeoNode 2.8.1), which implements this GNIP [2]. This pull request
>> > introduce the Harvard WorldMap contribute application in GeoNode.
>> > You can have a full list of the features introduced from the application
>> at
>> > [2]. In brief this application introduce a new client, based on an
>> improved
>> > version of the GeoExplorer default client, with additional features such
>> as:
>> > * layer categories in table of contents
>> > * layer graduated style editor
>> > * a find place widget and layers gazetteer
>> > * feature search
>> > * map revisions
>> > * URL permalink for maps
>> > * layer search with Hypermap Registry (optional)
>> > The application is optional and does not introduce any change in
>> existing
>> > GeoNode tables. If enabled, it will create a few new tables in GeoNode
>> > database, which are needed in order for the application to work. You
>> must
>> > use PostgreSQL to use this application, and PostgreSQL will require the
>> > PostGIS and dblink extensions.
>> > The GNIP implementation is based on current GeoNode WorldMap source code
>> > [3], and contains code committed by a number of GeoNode developers:
>> > * Matt Bertrand
>> > * Paolo Corti
>> > * Wayner Barrios
>> > * Jorge Martínez Gómez
>> > * Lennin Suescun
>> > * 刘尧 aka Lanni
>> > If there is consensus, this application will be merged in GeoNode source
>> > code as a contribute module.
>> > Thanks
>> > Paolo
>> > [1] https://github.com/GeoNode/geonode/pull/3817
>> > [2] https://github.com/GeoNode/geonode/issues/3718
>> > [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
>> > Paolo Corti
>> > Geospatial software developer
>> > web: http://www.paolocorti.net
>> > twitter: @capooti
>> > skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180531/9a5af4f3/attachment-0001.html>
More information about the geonode-users mailing list
