[Geoprisma-dev] Problem with zoomslider and template ordering
Stephen Woodbridge woodbri at swoodbridge.com
Mon Dec 7 09:43:54 EST 2009
Alexandre,
Thank you that solved one huge problem and I hope will let me move forward.
This is still a problem on r728 and trunk:
http://imaptools.com:8080/project/myproj2/index2.php
Try switch to OSM and the change back to WMS.
-Steve
Alexandre Dube wrote:
> Hi Stephen,
>  I think I found out why.  Try to replace your GeoExt.MapPanel layout
> property from 'fit' to 'anchor' and tell me if it works for you.  This
> requirement is not yet documented in the official doc yet, but it's in
> the ./doc/widgetdoc.txt file.
> I opened a ticket for the migration of all widget docs to Sphinx [1].
> Best regards,
> Alexandre
> [1] http://trac.osgeo.org/geoprisma/ticket/36
> Stephen Woodbridge wrote:
>> Hi all,
>> Ok, I have been trying to figure out why my zoomslider is broken.
>> I think I have found out why, but I'm not sure how to fix it.
>> If I look at the rendered html, the zoomslider is getting attached to
>> the map object before the zoomslider object is defined.
>> You can see this by loading the project url below, then view source
>> and search for the string "zoomslider"
>> http://imaptools.com:8080/project/myproj/
>> http://imaptools.com:8080/project/myproj/config.xml
>> http://imaptools.com:8080/project/myproj/xslt/default.xslt
>> I'm guessing it is a problem with something in the order of stuff in
>> my template, but it might be a bug also. Anyway, a little help from
>> your very busy schedules would be appreciated.
>> Thanks,
>>   -Steve
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
More information about the Geoprisma-dev mailing list
