[Geoprisma-dev] QueryOnClick - Highlight results of query
Alexandre Dube adube at mapgears.com
Fri Nov 6 09:20:08 EST 2009
Yves Moisan wrote :
Just saw something interesting on the OL list :
"So I have an OpenLayers map that has a WMS Layer on it, and a
GetFeature control that uses the WFS.fromWMSLayer Protocol in
conjunction with a Vector Layer to highlight a selected Feature."
So it seems like it is possible to highlight what is selected with a
queryonclick highlighted in the WMS (or does that return the
corresponding features ?).  That would potentially make the marker issue
moot.  That could also probably be used in the InitialView widget.
I'll put that in Trac when the JIRA history is shoved in.
Yves
Alexandre Dube answered :
That could be only possible if a vector layer (of the same resource) was
added to the map and if the QueryOnClick widget was enhanced with a
"AutoResourceActivation" tool, like the Shortcut widget.  Do you see
what I mean ?
Unless there's a vector layer of the same resource, it would be
impossible to "highlight" anything with a simple getfeatureinfo request...
Alexandre
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
