[Geoprisma-dev] Access control docs
François-Luc Bergeron flbergeron at nippour.ca
Tue Nov 10 13:43:08 EST 2009
Julien-Samuel Lacroix a écrit :
> Hi,
> Yves Moisan wrote:
>> I think the most likely use case will be a web developer who has never
>> had to bother setting up a security environment.  The learning curve may
>> be steep here.  What does that developer need to know to easily test
>> security (e.g. with an XML file) ?
> I there's a lot to do before having a good doc/tutorial that
> demonstrate that. Let's begin small by having a few samples showing
> the Access Control in action then we'll do some doc and then tutorials
> to integrate the BD instead of the XML.
> From my experience that worst when setuping GeoPrisma is to correctly
> define all Resources and assigning them to the right user. Maybe
> François-Luc can share his experience as he is the perfect case of:
> You know nothing about webmapping and you are dropped in GeoPrisma.
> François-Luc?
> Julien
I used the ACL sample to understand and how to integrate AC in my
application, the comments in the code were really helpful. Alexandre and
Julien also helped me so i wasnt alone with the doc! Overall i dont
remember it as something very hard to do.
Programmeur informatique
Nippour
More information about the Geoprisma-dev mailing list
