[Geoprisma-dev] Legend Panel - Scrollbar
louis.rocheleau louis.rocheleau at boreal-is.com
Thu Nov 26 05:11:47 EST 2009
Hello again,
I have configured a Legend Panel for the layers on a GP map. It goes all
fine using the Sample1 example. My only concern is when you reach a certain
number of elements in the Legend Panel, you can't see all the information,
as there is no scroll bar. Is there any development on having such a tool ?
I am not sure but would the layer tree act the same if too many layers were
defined ?
Thanks
Louis
View this message in context: http://n3.nabble.com/Legend-Panel-Scrollbar-tp41268p41268.html
Sent from the GeoPrisma-dev mailing list archive at Nabble.com.
More information about the Geoprisma-dev mailing list
