[Geoprisma-dev] Tutorial - How to create a GeoPrisma project
Stephen Woodbridge woodbri at swoodbridge.com
Mon Nov 30 13:48:24 EST 2009
Yves Moisan wrote:
> L
>> Given enough time and money, then sure, we should add a set of more
>> hands-on exercise to complement this more abstract tutorial. The
>> MapServer tutorial is a good example of what we could aim for:
>> http://biometry.gis.umn.edu/tutorial/sections.html
>> However, until the resources are available to produce this level of docs
>>   I consider that what you've got is a great start.
>> Thanks for you work on this Alexandre.
> Agreed !  Thanx for doing that work.
Since I raised the question, I would like to give my thanks to Alexandre
also. The Tutorial has improved significantly since I first looked at it.
Since I'm new to GeoPrisma and this is my first time through the
tutorial and the fact that I know a lot about the related technologies,
I thought it might prove useful with regards to ways to improve the
"newbie" experience with GeoPrisma. I'll continue to report issues and
successes with the hope that they might prove useful to the team and/or
users in the future that might be searching the archives.
So, Alexandre, in case it was not obvious in my flood of issues to the
list, you are doing a great job and I appreciate the tutorial and your
support on and off the list.
-Steve W
More information about the Geoprisma-dev mailing list
