[Geoprisma-dev] XMLConfig 'reload' method
Alexandre Dube adube at mapgears.com
Mon Aug 16 14:58:36 EDT 2010
Hi devs,
   I'm not sure I quite understand the use of the 'reload' method
defined inside XMLConfig.php.  What is it used for ?  When should it be
used ?  Should it be implemented for the PGSQLMapContextConfig driver as
well ?
Thanks,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
