[Geoprisma-dev] Cleanup the samples
Alexandre Dube adube at mapgears.com
Fri Dec 10 09:51:38 EST 2010
   Below is a list of all the current samples and those I checked as
"removal".  All kept samples should point to the sample template, if
possible (acl2 isn't for example, the filetreepanel doesn't need a map,
etc.), their original template file should be removed as well and they
should have new header/footer files to explain what they do.
   Finally, it is important to notice that in the end, we'll always need
2 templates until the Map widget disappear.  Since the MapPanel and
Layer widget don't do 100% of the features the Map widget does (like
merging layers), it should be kept.  Since the Map widget also needs
MapFish-client javascript but not the two others, we need 2 templates
(unless I find an easy way to detect which widget is present and load
the according libs).  I'll have to see...
Do you agree with this list :
=== REMOVE ====
alloverlays
bdga
geoextux/geonamessearchcombo
google/default
helloworld
mapfishlayertree
merge_split
pdfprint/withprintproxy
quickzoom
release
sample0
sample1/auth_josso
sample1/auth_xml
sample1/default
sandbox1/auth_josso
sandbox1/auth_xml
sandbox1/default
wmslayeradder
=== KEEP ===
acl2
borealis-authentification
complex_workspace
filetreepanel
geoextprintform/alllayers
geoextprintform/xmlconfignoacl
geoexttoolbar/pgsqlconfig
geoexttoolbar/withseparator
geoexttoolbar/customcontrols
geoextux/shortcutcombo
geoextux/zoomto
geoextux/redliningpanelintoolbar
geoextux/layertreebuilder
htwindow
initialview
mappanel/gymo
mappanel/simple
navtools
onegeology/default
proxycaching/simple
queryonclick/wms130
queryonclick/simple
queryonclick/myownmarker
queryonclick/useresponsefields
scale
shortcut/inpanel
shortcut/intoolbar
shortcut/activateresources
workspace
On 10-12-10 09:35 AM, Alexandre Dube wrote:
> Also, please let me know if there is any objection of removing all
> samples showing deprecated widgets, multiple widgets (bdga, sample1,
> etc.), etc.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
