[Geoprisma-dev] Cleanup the samples
Yves Moisan yves.moisan at boreal-is.com
Fri Dec 10 14:00:20 EST 2010
Hi Alexandre,
Sounds good.  Please see below some specific widgets I would rather not
clear right now.
Thanx.
Yves
> Do you agree with this list :
> === REMOVE ====
> alloverlays
> bdga
> geoextux/geonamessearchcombo
> google/default
> helloworld
> mapfishlayertree
Would keep in a "deprecated" section; just so we users of the old
widgets still have examples to rely on ...
> merge_split
> pdfprint/withprintproxy
Would keep in a "deprecated" section; same reason as above; we will
start implementing your replacement widget in 2011 for sure.
More information about the Geoprisma-dev mailing list
