[Geoprisma-dev] Updated samples on GP website missing includes
Alexandre Dube adube at mapgears.com
Tue Dec 14 09:38:51 EST 2010
Thanks Yves for your time.
So this is as I suspected, there is something wrong when using a windows
platform.  I attached here what the demo should look like.  I'll attach
in the next message the code source of the footer that is supposed to be
added to the template as well.
Any hint ?
Alexandre
On 10-12-14 09:32 AM, Yves Moisan wrote:
> Le 2010-12-14 08:55, Alexandre Dube a écrit :
>> Hi,
>>   The way I read and copy the content of the header.inc.html and
>> footer.inc.html files for the samples and it unique template file
>> works fine on my local linux machine, but on http://www.geoprisma.org
>> it's not working.  Both files are not included.  Here's a sample
>> using the new template, you'll see not header, nor footer contents :
>>   http://www.geoprisma.org/samples/zoomslider/index.php
> Is there one of the samples with the new *.inc.html machinery that
> works on georprisma.org ?  I updated SVN this morning on my windows
> machine and I don't see anything different than what I see on
> geoprisma.org.  If no samples work, can you attach a screeshot so I
> know what to expect ?
> The only thing I can confirm for now is that it does not work locally
> on a windows box.
> Yves
Alexandre Dubé
Mapgears
www.mapgears.com
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20101214/0854634a/zoomslider-demo-0001.jpg
More information about the Geoprisma-dev mailing list
