[Geoprisma-dev] Cleanup the samples
Yves Moisan yves.moisan at boreal-is.com
Tue Dec 14 14:09:03 EST 2010
>> I think it's a worthwhile objective to try and minimize the amount of
>> widgets (whence, JS to read ...) for a given example.  At any rate,
>> we can always chime in and modify the examples later on.
> Do you mean we should postpone the remaining things for later ?
I mean do what you propose for the 3 samples : remove them with simpler
ones.
Cheers,
Yves
More information about the Geoprisma-dev mailing list
