[Geoprisma-dev] Updated samples on GP website missing includes
Alexandre Dube adube at mapgears.com
Tue Dec 14 14:27:28 EST 2010
Yves,
   All samples now use the ./src/client/templates/samples.xslt and
that's where the call of the methods are being made.
Regards,
Alexandre
On 10-12-14 02:07 PM, Yves Moisan wrote:
> Hi Alexandre,
> I can confirm the functions you wrote to get the header/footer files
> resolves to a real file (echo debugging says).  When I go "echo
> getSampleHeader();" in index.php I see a good string.  Why it is not
> included in the final page is a bit beyond my PHP/JS skills.  I can't
> see where getSampleHeader() is called.  I thought the problem might
> have been due to some different way of accessing files between OS'es,
> but it may be more a JS issue.  The only thing I notice in FireBug is
> that the style.css file is sought in the samples/zoomslider directory
> whereas it is in the samples/ dir.  I'll try and give it another spin
> later today.
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
