[Geoprisma-dev] Securing services
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 28 15:36:43 EST 2010
Yves Moisan wrote:
> Hi List,
> Did any of you folks secure MapServer, TileCache and FeatureServer using
> Apache directives and if so can I have "recipes" to do it efficiently ?
I have not done this yet, but my plan was very simple. Just make the
services you want secured only available on localhost so that the proxy
can access them but the remote client can not.
> Do I need an .htaccess file or just httpd.conf settings ?
I do not believe there is anything that can be put into a .htaccess file
that can not alternatively be done in the http.conf or one of the
vhost.conf files.
Really securing a server takes some thought, because if you have
mapserver or other webservices running on it wide open for other
applications these might be back doors into your data and like if know
the path to your mapfile I might be able to access it via one of the
other instances by specifying it directly. So if you are going to have a
secure server then you probably want to avoid exposing the cgi-bin to
the public ip address and you need to make sure you appropriate secure
all web services that you proxy hits. One way to do this is only make
those services available on a priviate ip or via localhost. I guess I'm
trying to say you need to do two things:
1) secure you intended services
2) make sure other unsecured services can not be compromised to access
your data
Just my two cents - this is a good question and probably should be
discussed and written up in the wiki or docs somewhere.
-Steve W
> TIA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
More information about the Geoprisma-dev mailing list
