[Geoprisma-dev] Edit (create) issue
Yves Moisan yves.moisan at boreal-is.com
Thu Jul 22 11:51:37 EDT 2010
Le 2010-07-22 10:51, Yves Moisan a écrit :
> Hi All,
> Anybody had a problem like objGPWidgetCreateSomething_Point is not
> defined (Firebug) ?
> The final JS indeed tries to assign attributes to a var that is
> defined afterwards :
> objGPWidgetCreateSomething_Point.setFeaturePanel(objGPWidgetFeaturePanelFormSomething);
> e.g. on line 2726
> var objGPWidgetCreateSomething_Point = new
> OpenLayers.Control.EditFeature_Create(objWidgetOptions);  e.g. on line
> 2753
> Looking at the Create.xslt file shows the variable declaration is the
> first thing done (line 20).  Any clues ?
Got it.  It was a configuration issue, or rather a GP issue ...  The
thing is the order of widgets inclusion in the resource is important.
The FeaturePanelForm must be listed **after** the Create widget :
<!-- Order = OK -->
<resource>
<name>RS_something</name>
<widgets>
<widget>Toolbar</widget>
<widget>QueryOnClick</widget>
<widget>CreateSomething_Point</widget>
<widget>FeaturePanelFormSomething</widget>
</widgets>
</resource>
<!-- Order != OK -->
<resource>
<widgets>
<!-- BAD ORDER !! -->
</widgets>
</resource>
Bad ordering caused 2 things : 1) raise the FB error mentioned above and
2) no featurepanel would popup upon creating a new feature.
Phew ...
Yves
> TIA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
More information about the Geoprisma-dev mailing list
