[Geoprisma-dev] Order for GP Javascript
Yves Moisan yves.moisan at boreal-is.com
Wed Mar 17 11:03:28 EDT 2010
> There's no strict order other than MAP first.
> Julien
Thanx Julien.  I ran our JS's through jsbuild and found out there are
issues with our usage of the @requires comment.  Some of the @requires
we use point to things that do not exist (e.g. OpenLayers/Result) and
for some reason the @requires in GeoPrisma are not resolved by jsbuild.
In create.js for example :
@requires OpenLayers/Control/DrawFeature.js
results in
jstools.merge.MissingImport: File 'OpenLayers/Control/DrawFeature.js'
not found in root directories
even though the root directory for OpenLayers is specified correctly.
It's probably a bug in jsbuild, but to make things work, I deleted all
@requires from our js files.  It's a short term (not committed of
course) solution to minify our JS.
Things I noticed :
- all @requires directives in GeoExt relate to itself only (e.g.
GeoExt.xyz.abc)
- almost all those of OL relate to itself too (excet for a Gears js)
- only mapfish specifies @requires directives that point to paths other
than what's in it's lib; but mapfish has all it's dependencies in mfbase
I'll come back with more later.
Yves
More information about the Geoprisma-dev mailing list
