[Geoprisma-dev] PHP/Mapscript dependencies
Julien-Samuel Lacroix jlacroix at mapgears.com
Tue Oct 5 15:51:45 EDT 2010
We didn't test mod_php with something else than prefork for a while now.
What you point out seems to suggest that it's better to not use mod_php
under windows. I invite you to share this information on the MapServer
mailing-list. People there may have different experience.
Julien
On 10-10-05 03:23 PM, Yves Moisan wrote:
> Also http://httpd.apache.org/docs/2.0/mpm.html says
> "MPMs must be chosen during configuration, and compiled into the server
> ... The following table lists the default MPMs for various operating
> systems. This will be the MPM selected if you do not make another choice
> at compile-time.
> BeOS beos
> Netware mpm_netware
> OS/2 mpmt_os2
> Unix prefork
> Windows mpm_winnt "
> So people wanting prefork on windows must recompile Apache or else they
> get the default mpm_winnt. I tried looking if MS4W had any compilation
> settings for Apache under windows but didn't find yet.
> Another interesting post: http://www.devside.net/articles/php :
> "Warning: We do not recommend using a threaded MPM in production with
> Apache2. Use the prefork MPM instead, or use Apache1." They also have
> interesting sections like "PHP as an Apache2 module [the right way]".
> HTH,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
