[Geoprisma-dev] SVN problem with Ext JS lib
Etienne Dube etienne.dube at boreal-is.com
Fri Oct 15 09:40:54 EDT 2010
  On 15/10/2010 8:20 AM, Alexandre Dube wrote:
> On 10-10-14 05:44 PM, Yves Moisan wrote:
>>  The Ext source at
>> http://trac.geoext.org/browser/ext/3.2.1/docs/source shows only
>> Menu.html.  I was thinking there would be an svn:externals in
>> trunk/lib pointing to Ext 3.2.1 but it's not the case.  Was the Ext
>> code checked out on a *NIX box then commited back into GP's SVN ?
>> Maybe we could try removing Ext-3.2.1 and using an externals instead ?
> We could do that.  It wouldn't need to be an external though.  We
> could download the ext 3.2.1 from geoext repository then remove all
> .svn folders from it and replace the one in ./lib by this new one.
> But moving it to svn could do the trick too.
I removed the offending menu.html file from the trunk, for the moment
that will do the trick so we can update our local copies.
Etienne
Etienne Dubé
Consultant / Développeur
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Tel. :  514.313.5951 #1131
Courriel: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
