[Geoprisma-dev] Error on update to r913 with QueryOnClick
Yves Moisan yves.moisan at boreal-is.com
Tue Oct 19 11:18:39 EDT 2010
  Le 2010-10-18 13:39, Alexandre Dube a écrit :
> Hi,
>   Which sample is showing the issue ?
>   Also, 'displayfields' is not a supported option of the queryonclick
> widget and should be removed from any config :
> http://www.geoprisma.org/dist/build/html/widgets/list/QueryOnClick.html#mandatory-options
> http://www.geoprisma.org/dist/build/html/widgets/list/QueryOnClick.html#optional-options
Right.  Thanx for the info.  All is well now.
Cheers,
Yves
More information about the Geoprisma-dev mailing list
