[Geoprisma-dev] Tilecached layer (jpeg tiles) with scale dependent visibility
Julien-Samuel Lacroix jlacroix at mapgears.com
Fri Sep 3 11:16:35 EDT 2010
Hello,
Did you try with <minscale>10000</minscale> in lowercase in the map
widget? I suspect it may solve your problem. If seems that the option is
in lowercase in the map widget and with an uppercase S in the
mapfishlayertree. :S
Julien
On 10-09-03 10:26 AM, Djoan Bonfils wrote:
> Hello,
> I'm trying to make a Tilecached layer (with jpeg tiles) invisible at a
> certain scale (when zooming in).
> I placed a <minScale>10000</minScale> in
> <layer>
> <resourcenames>
> <resourcename>RS_pngtopo</resourcename>
> </resourcenames>
> <servicetype>tilecache</servicetype>
> <options>
> <layername>LYRRS_pngtopo</layername>
> <maxextent>584694,8947004,1342974,9702822</maxextent>
> <isbaselayer>false</isbaselayer>
> <projection>EPSG:32754</projection>
> <singletile>false</singletile>
> <transparent>true</transparent>
> <buffer>0</buffer>
> </options>
> </layer>
> and in:
> <node>
> <textkey>Topo PNG</textkey>
> </node>
> The node is greyed at the desired level but when it was checked before
> zooming in, it stays checked after zooming past the minScale...Therefore
> the layer is still displayed. Is there a way to not show the layer pas
> the desired scale.
> Thx
> Djoan
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
