[Geoprisma-dev] GetlegendGraphic called each time zooming in or out (r805)
Djoan Bonfils djoan.bonfils at boreal-is.com
Tue Sep 7 11:41:33 EDT 2010
  Hello,
When adding
<resource>
<name>RS_issues_by_location</name>
<widgets>
<widget>Toolbar</widget>
<widget>W_MyLegendPanel</widget>
</widgets>
</resource>
to get the legend Panel, using firebug, I observed  that a
getlegendGraphic is performed on each layer each time I'm as zooming in
or out even when these layers are not checked.
I was wondering how this was affecting global performances...
Regards
Djoan
>  Hello,
> We checked in \src\client\widgets\map\map.xlst
> in the layer options, minscale is not defined
> We succeed in obtaining the desired effect by (make the layer not
> visible at a certain scale) by defining an array of scales within the
> option scales.
> Strangely the option resolutions didn't do the job...
> We use r805 ,  if minscale is not already defined in newer releases
> may be adding it will be helpful.
> Regards
> Djoan
>> Hello,
>> Did you try with <minscale>10000</minscale> in lowercase in the map
>> widget? I suspect it may solve your problem. If seems that the option
>> is in lowercase in the map widget and with an uppercase S in the
>> mapfishlayertree. :S
>> Julien
>> On 10-09-03 10:26 AM, Djoan Bonfils wrote:
>>> Hello,
>>> I'm trying to make a Tilecached layer (with jpeg tiles) invisible at a
>>> certain scale (when zooming in).
>>> I placed a <minScale>10000</minScale> in
>>> <layer>
>>> <resourcenames>
>>> <resourcename>RS_pngtopo</resourcename>
>>> </resourcenames>
>>> <servicetype>tilecache</servicetype>
>>> <options>
>>> <layername>LYRRS_pngtopo</layername>
>>> <maxextent>584694,8947004,1342974,9702822</maxextent>
>>> <isbaselayer>false</isbaselayer>
>>> <projection>EPSG:32754</projection>
>>> <singletile>false</singletile>
>>> <transparent>true</transparent>
>>> <buffer>0</buffer>
>>> </options>
>>> </layer>
>>> and in:
>>> <node>
>>> <textkey>Topo PNG</textkey>
>>> </node>
>>> The node is greyed at the desired level but when it was checked before
>>> zooming in, it stays checked after zooming past the
>>> minScale...Therefore
>>> the layer is still displayed. Is there a way to not show the layer pas
>>> the desired scale.
>>> Thx
>>> Djoan
>>> Geoprisma-dev mailing list
>>> Geoprisma-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Djoan Bonfils
Gis&  Business Analyst
Boréal Informations Stratégiques
         www.boreal-is.com
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1 CANADA
Tel :  +1 514 313 5951 #1128
More information about the Geoprisma-dev mailing list
