[Geoprisma-dev] HISTORY file
Alexandre Dube adube at mapgears.com
Fri Dec 2 11:23:12 EST 2011
Devs,
   Here's some more details on the matter.
   * All entries in a HISTORY.txt file must be added on top-most portion
named "Current Version"
   * All commits made as bug fixes on a stable branch *must* includes an
entry in its HISTORY.txt file.
   * A commit made on *trunk* doesn't require en entry in its
HISTORY.txt.  If it's a major bug fix, a new feature or new widget, it's
must be added.  If it's a minor fix or enhancement, it shouldn't be added.
   * When a new release is made, the "Current Version" changes its name
for the release name, for example "1.0.1".
   * The *commiter* should take care of updating the HISTORY.txt files,
but should the patch contain the change it's okay.
Best regards,
Alexandre
On 11-12-01 03:11 PM, Alexandre Dube wrote:
> Devs,
>   An "HISTORY.txt" file has been added to GeoPrisma :
> http://trac.osgeo.org/geoprisma/browser/projects/geoprisma/trunk/HISTORY.TXT
>   From now on, all commits made in GeoPrisma source code must includes
> a line describing the change in that file.  It will follow the same
> approach as MapServer, so you can take a look at this one as an example :
>     http://trac.osgeo.org/mapserver/browser/trunk/mapserver/HISTORY.TXT
> Best regards,
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20111202/c0838e7b/attachment.html
More information about the Geoprisma-dev mailing list
