[Geoprisma-dev] FeaturePanel_AttribueForm
Alexandre Dube adube at mapgears.com
Wed Jan 26 11:43:53 EST 2011
   Well, I'm a bit disappointed to state that it will not be possible to
avoid having to manually define the fields to edit.  Here's the fact :
   I thought when clicking on a feature, I could simply take the
attributes already existent and build a form with that.  That works, but
when creating a new feature, I need that list from somewhere else since
the feature itself doesn't have any attributes yet.  I would need a
DescribeFeatureType request equivalent in FeatureServer but
unfortunately there isn't such a thing.  It is also out of the question
to manually generates a request that would return only one feature for
that purpose because if the data has no features yet, it wouldn't work.
   So, it's kinda back to square one.  If we used WFS, we could use the
GeoExt.data.AttributeStore already existant in GeoExt lib...
   For now, I have no choice but to proceed using a new 'fields' tag
inside the resources.  If anyone has any comments, you're welcome to
state them.
Thanks,
Alexandre
On 11-01-25 02:09 PM, Alexandre Dube wrote:
> Devs,
>   After analysing the efforts it would take to implement the
> FeaturePanel_Form inside the PGSQLMapContextConfig driver, we came to
> the conclusion that it would be too hard to do and also very dirty.
>   Here's the solution we came up with : a new
> FeaturePanel_AttributeForm widget.  See the details [1].  It will be
> usable in all XML configs and the DB config as well, will have a very
> short configuration, etc.
>   I'll get on it right away and let you know of my progress.
> Best regards,
> Alexandre
> [1] http://trac.osgeo.org/geoprisma/ticket/183
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
