[Geoprisma-dev] Merge of the attributefilterpanel branch
Etienne Dube etienne.dube at boreal-is.com
Mon May 9 17:37:04 EDT 2011
Hi Alexandre,
Thanks for your (and Julien's) input. I did the merge (r1034),
everything seems fine on my local copy. I'll make sure to configure the
FeatureServer datasource on the geoprisma.org machine to make the new
sample work correctly.
PGSQLMapContextConfig isn't supported by the widget yet, so your help
would definitely be welcome. I'll let you know when I have some time to
spend on that.
Etienne
On 09/05/2011 8:15 AM, Alexandre Dube wrote:
> +1
>   If the widget isn't supported by the PGSQLMapContextConfig driver
> already, please let me know if you need help to support it.
> Thanks a lot for your hard work,
> Alexandre
> On 11-05-06 09:25 AM, Etienne Dube wrote:
>> Hi,
>> I would be ready to merge the branch for the attributefilterpanel
>> widget back into the trunk. The sample is ready, I only have to
>> configure a new FeatureServer datasource on the geoprisma.org host
>> for the sample vector data. The widget is still experimental (and I'd
>> like to make it work with the new ResultVectorLayer described in
>> ticket #214) but I'm comfortable with it being in the trunk.
>> Any comments or opinions welcome.
>> Thanks,
>> Etienne
Etienne Dubé
Developer
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Canada
Tel. :  514.313.5951 #1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
