[Geoprisma-dev] Merge of the attributefilterpanel branch
Etienne Dube etienne.dube at boreal-is.com
Tue May 10 11:18:02 EDT 2011
On 10/05/2011 8:06 AM, Alexandre Dube wrote:
> On 11-05-09 05:37 PM, Etienne Dube wrote:
>> Hi Alexandre,
>> Thanks for your (and Julien's) input. I did the merge (r1034),
>> everything seems fine on my local copy. I'll make sure to configure
>> the FeatureServer datasource on the geoprisma.org machine to make the
>> new sample work correctly.
> Or you could pick any from the existing samples, like the
> dev4g.mapgears.com one.
Good idea, I'll rework the sample to use the "GMap cities" vector layer
instead.
Thanks,
Etienne
>> PGSQLMapContextConfig isn't supported by the widget yet, so your help
>> would definitely be welcome. I'll let you know when I have some time
>> to spend on that.
> Got it.
> Regards,
Etienne Dubé
Developer
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Canada
Tel. :  514.313.5951 #1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
