[Geoprisma-dev] Ticket 248 - ResultExtGrid - use of resource field options
Alexandre Dube adube at mapgears.com
Fri Apr 27 12:03:21 EDT 2012
   [Fix] applied, [sample] and [doc] updated.  To all trunk users, make
sure you test the fix and report any issue.
Regards,
Alexandre
[Fix] http://trac.osgeo.org/geoprisma/ticket/248#comment:6
[sample] http://www.geoprisma.org/samples/queryonclick/simple/index.php
[doc]
http://www.geoprisma.org/dist/build/html/widgets/list/stable/ResultExtGrid.html
On 12-04-24 03:29 PM, Alexandre Dube wrote:
> Hi,
>   I've got a patch ready :
>     http://trac.osgeo.org/geoprisma/ticket/248#comment:5
>   If anyone wants to review, please do.  Otherwise, I plan to commit
> this tomorrow.
> Thanks,
> Alexandre
> On 12-04-24 02:09 PM, Alexandre Dube wrote:
>> Hi,
>>   In the next hours/days, I'll be working on this ticket :
>> http://trac.osgeo.org/geoprisma/ticket/248.
>>   In short, we want this widget to be able to use resource fields
>> instead of having to define them inside the widget options.  We still
>> want to old way to work.  So, for XML drivers, both ways are going to
>> be possible to use.  For the PGSQLMapContextConfig driver, we'll make
>> a major change in the way the widget is built by the php file, but in
>> the front end, nothing will need to be changed.
>>   Trunk users, be aware of this change.  I'll let you know once I
>> commit it.  I'll document it in the 1.4 Release plan, in the wiki.
>> Thanks,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
