[Geoprisma-dev] GeoPrisma 1.2.0 release
Alexandre Dube adube at mapgears.com
Fri Jan 27 15:12:22 EST 2012
The GeoPrisma Development Team is proud to announce the release of
GeoPrisma 1.2.0, which closes 79 outstanding tickets !
The GeoPrisma 1.2.0 source code can be downloaded from:
   http://geoprisma.mapgears.com/download/geoprisma-1.2.0.tar.gz
or using SVN at :
   https://svn.osgeo.org/geoprisma/projects/geoprisma/tags/rel-1-2-0/
The 1.2 branch was also created and is available at :
   https://svn.osgeo.org/geoprisma/projects/geoprisma/branches/branch-1-2/
The GeoPrisma 1.2.0 documentation is available at :
   http://geoprisma.mapgears.com/docs/1.2/
The 1.2.0 release adds several important features. Some of the
highlights include:
  * A new API widget used as a way for external libraries to communicate
with GeoPrisma.
  * A new ApplyFilter widget that apply filters on resource WMS layers
using SLD and displaying results in a paging grid using WFS
  * A completely revised version of the InitialView widget
  * Updates to allow a better initial center or extent of the map on load.
  * New cool options for the XMLWorkspaceConfig driver to define unbound
widgets and override MapPanel options.
  * A new TMS Service and Proxy.
and many more fixes.  See the full documentation about the GeoPrisma
1.2.0 Release at :
   http://trac.osgeo.org/geoprisma/wiki/Release/1.2
For information on possible changes that will need to be made between
this version of GeoPrisma and previous versions, please look at the
Migration Guide available available at :
http://trac.osgeo.org/geoprisma/wiki/Release/1.2/Notes#MigrationGuide:GeoPrisma1.0to1.2
Please help out by testing your applications with this new code base.
Thanks! - The GeoPrisma Team
P.S. The geoprisma.org doesn't yet point on the new Linux server yet, so
the above download and doc links point to geoprisma.mapgears.com.  This
will change back to geoprisma.org as soon as the move is completed.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
