[Geoprisma-dev] Variable substitution in GeoPrisma configuration
Etienne Dube etienne.dube at boreal-is.com
Thu Jun 21 13:44:43 PDT 2012
Hi all,
I've been thinking of a useful feature to add to GeoPrisma: variable
substitution for configuration parameters.
Rationale:
Suppose you have a very long and complex XML configuration file. This
file will be deployed in different environment, all with different
characteristics: development, test and production. Each environment can
have its own file paths and different URLs to access the services. It is
somewhat of a pain to maintain three separate XML configuration files
for these environments. Wouldn't it be awesome if instead, we could just
use placeholder variables for the environment-specific parts of the
configuration, and have GeoPrisma load the values for these variables
from an external source (be it a properties file or a database table)
and substitute them dynamically at runtime?
For example:
In gp.xml:
<services>
   <wms>
     <name>S_MyWMS</name>
     <srs>*</srs>
     <format>*</format>
     <source>http://${s_mywms_host}/mywms</source>
   </wms>
</services>
In gp.properties for development env.:
s_mywms_host=devserver.bovine-university.edu
In gp.properties for production env.:
s_mywms_host=prodserver.bovine-university.edu
... and so on.
Implementation considerations:
Now from what I've gathered, the logical place to add such a feature
would be in Config.php. However the different implementations of the
Config abstract class have their own way of getting their configuration
attributes from their respective source (XML file or DB), so changes to
these subclasses would be required as well (probably in
XMLConfig.simpleXMLToArray() and PGSQLMapContextConfig.getRecords() ).
A few questions as well:
  - Do we want to allow variable substitution for all configuration
parameters? Or should we restrict it to only specific elements such as
services?
  - Should we provide a way to escape the variable placeholders (${...}
-- another syntax could be used as well), to allow the uncommon
occurrences of passing a string containing ${...} as is?
  - What would be the best way to reference the external properties file
/ table? Should it be a parameter in the configuration, or do we want to
have it hardcoded (e.g. always look for a gp.properties file in the same
location as gp.xml).
As always, any input is appreciated.
Thanks!
Etienne
Etienne Dubé
Developer
Boreal - Information Strategies
202A-101 rue du Moulin
Magog, Québec, J1X 4A1, Canada
http://www.boreal-is.com
Tel. :  +1 514 313 5951 ext:1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
