[Geoprisma-users] Re: [Geoprisma-dev] Trac
Yves Moisan yves.moisan at boreal-is.com
Mon Nov 9 08:52:44 EST 2009
> Thanks a lot for the efforts.
>   Should we have more detailed components, like OpenLayers - MapServer -
> GeoExt - etc do ? Like :
>   Widget
>   Widget - QuickZoom
>   Widget - MapFishRecenter
>   Widget - Merge
>   etc.
> Alexandre
Hi Alexandre,
I was going to answer you I thought we had enough components for now,
but I checked the GeoExt Trac and they have quite a few.  I'm not sure
we need a detailed set of components at this point.  Or maybe you'd like
to sort active tickets per component type ?  Trac provides default
filters for version and milestone.  Do we need to filter by component ?
Cheers,
Yves
More information about the Geoprisma-users mailing list
