[Geoprisma-users] New to GeoPrisma - Samples don't work
Stephen Woodbridge woodbri at swoodbridge.com
Thu Nov 12 23:46:59 EST 2009
Hi all,
I have downloaded geoprisma-r699 and the release demo works but I get
errors with the other samples:
http://imaptools.com:8080/gp/samples/acl/index.php
Warning: require_once(com/borealis/Autoload.php)
[function.require-once]: failed to open stream: No such file or
directory in /var/www/geoprisma-r699/samples/acl/roles.php on line 14
Fatal error: require_once() [function.require]: Failed opening required
'com/borealis/Autoload.php'
(include_path='.;/var/www/geoprisma-r699/samples/acl/../../lib/borealis-foundation-0.1.0.0;/var/www/geoprisma-r699/samples/acl/../../lib/borealis-acl-0.1.0.0;/var/www/geoprisma-r699/samples/acl/../../lib/Smarty-2.6.22/libs')
woodbri at mappy:/u/www/html/gp$ find . -name Autoload.php
./lib/php-borealis-foundation-0.3.1.28/com/borealis/Autoload.php
I probably have to look for where the path gets set and maybe update
that assuming that the versions may or may not be compatible.
-Steve W
More information about the Geoprisma-users mailing list
